Question about Husqvarna Chain Saw 20" Bar
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
When it threw the chain it may have damaged the guide teeth on the under side of the chain remove chain and file the guide teeth this as happened to me with 440 i have used many saws over the years and the 440 is the only that has ever done this
Posted on Jan 23, 2009
    Scholar:
  • 58 Answers
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Posted on Jan 10, 2009
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
How do you replace clutch on cs 350 echo chain saw
I am guessing what you are calling the clutch band is the anti kickback brake. It is operated by a "lever" in front of the hand grip on the front of the saw. Pull that lever towards the rear of the saw to get more slack in the band.
Jul 31, 2014 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The chain on my Echo saw is moving very slowly to not at all
Your centrifugal clutch needs to be replaced or your chain guide (bar) is pinched.
Mar 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
NEED TO FIND A NEW 14" CHAIN AND BAR FOR ECHO CS 305 SAW. NONE LISTED AT LOWES OR HOME DEPOT. THANKS FOR ANY INPUT.
What you are looking for is the following model bar:
Echo 14A4CD3752
If you cut and paste that into google or another search engine you will find numerous online retailers who can sell and ship you this bar for your CS-305 saw.
Apr 06, 2009 | Echo Garden
Husqvarna Chain Saw 20" Bar Logo
759 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
