Question about Ovens
Diplomat 900Ga gas oven shuts down after 20 min
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: oven shut down after 5 min of running
Need to know which oven you are reffering to and the model/serial number before I can assist you.
Posted on Jan 26, 2008
SOURCE: the oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Posted on Jul 20, 2009
  • 773 Answers
SOURCE: I have a diplomat 700ga
Your thermocouple is bad. Your oven has a safety device called a thermocouple. It detects the flame so that when the flame is not present, it will shut off the gas so that you do not have an explosive problem.
When the thermocouple goes bad, it cannot detect the flame, there for the gas will be shut off. Often times it will work okay for a short time, and then go out.
The thermocouple is a thin copper flexable tube that has a prob on one end that sits in front of the pilot light, and the other end screws into the gas valve.
This not a hard part to replace. You just unscrew the old one, take the prob out of the pilot assembly, and then put the new one in with the probe in place, run it back to the valve, and screw it in making sure it is in tightly.
Posted on Nov 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: Moved into a house with no manual for the oven.
Check your oven sensor. It should read around 1100 ohms @ room temp.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 25, 2010
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 | Ovens
Why does gas oven make a humming noise and shut off after 20 mins
Don't take risk and call the technician.
Aug 25, 2014 | Ovens
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 | Ovens
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
Stove top working, oven is not
you need to check the heating elements and make sure you have continuity if you do then replace the control board
Jan 29, 2010 | Frigidaire FEB27S5A Electric Single Oven
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
The oven turns off after 30 mins
Apparently!
Jul 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
65 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
