Question about Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY
What is error code for E805
I have changed the basic two fans in my cannon xerox machine but also after a few hours it display the same error. what is the problem in my machine and what is solution please the best idea for that problem
4 Suggested Answers
  • 37 Answers
SOURCE: CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Posted on Aug 26, 2009
SOURCE: E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Posted on Mar 03, 2010
  • 525 Answers
SOURCE: My xerox machine cannon IR
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Posted on Jan 20, 2011
What is a mining of shine E000805-0000 on xerox machin canon ir 2830
I don't have the service manual for this model but on many canon copy machine E805 is a fixing fan error.
Nov 21, 2014 | Office Equipment & Supplies
Ir3300 e805 error sollution
if cannon ir 2200-3300 shows error E00805-0000 THEN fixing fan is not workig fan is jam oiling d fan then fan is not work change fixing fan.
Jul 15, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon xerox ir 400 error E805 the problame is machin display open the front door
This problem due to your composite power supply,you can see 3 blue capasitor has burned,change it with 4 amp fuse near that caps
Sep 07, 2011 | Canon imageRUNNER 400S Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
Canon xerox
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 03, 2009 | Canon imageRUNNER 400S Copier
Ir400s cannon i am getting error 805
if you can go to service mode check the sub code of E 805 (means one fan motor is not working properly )the sub code tells
which fan is faulty
Jun 15, 2009 | Canon imageRUNNER 400S Copier
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Error code e805
The fan wiring is faulty (short circuit, open circuit). The heat dischargefan is fautly.
check wiring of heatdischarge fan
The machine is equipped with a single fan for discharge of heat from inside it.
Mar 04, 2009 | Canon imageRUNNER 2000 Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY Logo
20 people viewed this question
old marine
old marine
