Paper jamming in sharp ar m155 - Office Equipment & Supplies
  • 2072 Answers
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Mar 17, 2008
SOURCE: Sharp AR-M355 copier with AR-EF3 adf
With what you described it sound like the paper out sensor is not working properly, might be bad or broke. Hope that Helps... Lbcoaster
Posted on Jun 28, 2008
  • 990 Answers
SOURCE: my Sharp AR M205 has the error H4
Hello sir; Your machine require reset procedure; press "#", "interupt", "clear", "interupt" then enter 14 press start.
Posted on Jun 04, 2009
  • 10 Answers
SOURCE: my sharp AR-203E photcopier is flashing a number
on the control panel press clear button then interrupt button then zero button then interrupt button the display will change, then press 1 then 4 then start button then clear button (or power off) if you are blinking H then 5 it means you have had several jams in the fuser
Posted on Jan 08, 2010
  • 34 Answers
SOURCE: Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Posted on Mar 24, 2010
Testimonial: "Thank you so much for the help , I have tried the Bypass Tray but still getting the jam code."
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
SHARP AR-M155 system error[H4-00]
Apr 13, 2011 | Office Equipment & Supplies
HELLO I NEED SHARP USER MANUAL FOR DIGITAL AR-M155 PHOTO,PRINTER,SCANER,AND FAX. PLEASE SEND AS SOON AS POSSIBLE
Here's the manual: http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/AR-M150-M155-_E
Click on the "Download the complete user guide."
Fill out the four question survey or put in the security code to download file.
I tested to confirm that this is the right user manual.
Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
I have a Sharp AR-164 copier I have removed the paper jam cleaned everything out and it still says I have a paper jam how can I reset the copier??
turn power off, then back on. there might be a small piece of paper still blocking a senor. look down the middle very good.
Nov 03, 2009 | Sharp AR-164 Copier
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Pages come out black
It could be toner build up on the fuser rollers. If the jam was pulled from the fuser section.
Where was the jam at?
Nov 20, 2008 | Sharp AR-M237 Digital Copier
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
May 03, 2008 | Office Equipment & Supplies
48 people viewed this question
jasbo
jasbo
