Question about Western Digital (WD3200JS) 320 GB Hard Drive
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These are mov. files and some are larger than 4 gigs. The WD won't take them. Error 0 (It does take the smaller ones). When I check the drive for info is says that the format is MS-DOS FAT32. Is that the problem? Does it change when she looks at it on her PC? How can I change the format back to MAC? Or will that drive just not take larger files?
  • 36 Answers
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Posted on Jan 11, 2009
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
I want to reuse an ezquest cobra 250 gig external drive for time machine on a G5 powermac. the drive has files on it which are locked down. I want to wipe the drive and use it for back up. can this be...
Go to your applications folder and then to the utilities folder, find the application disk utility and then double click on it. Select your hard drive on the left hand column and then click on the erase button and select the format you require for the drive. Usually for a mac only backup you would use the format of Mac OS extended (journaled) or if you want to use the drive for mac and PC use the MS-DOS (Fat) option then click erase. Hope this helps.
Aug 05, 2011 | EZQuest Cobra USBII 250 GB USB 20 Hard...
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
My iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
Dec 09, 2010 | Iomega 33089 250 GB Hard Drive
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
My WD wants to install syn software. None of the files look like the files originally pulled for backup. My hard drive crashed and I need to restore to a new Hard drive - what do I do?
When you connect the drive, ignore the sync option. Do note in your "my computer" WD will have two drive letters (one is a read only drive) that contains the sync software. The other drive letter will be where you data is stored. If you used the sync software to backup your files; you need to install to get your data back. If you simply copied your data from one drive to another; the files should be there in their original form.
Oct 18, 2010 | Western Digital WD Passport 250GB Portable...
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Where do I find answer id 287 I want to format my wd drive as a mac drive in osx
where do I find answer id 287 I want to format my wd drive as a mac drive in osx
Sep 24, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Harddrive is not recognisable by both PC and MAC.. Its either one or the other..
Partition the drive into 2 250 Gig partions, Call 1 partition MAC and the other one name PC, for the apropriate partion on each machine
Apr 13, 2009 | Computers & Internet
My MAC won't recognize my WD 80 GIg External HD
Some computers (especially Mac laptops) don't send enough power through the USB port to power a passport, so you need to get an extra power cord, one that combines 2 USB ports into one to get a little extra juice. Wish I could give you a website where you can buy that extra cord but I am currently looking for one myself at this moment in time.
Nov 16, 2008 | Western Digital Passport WDXML800UE...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
230 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
