Question about GPX MW3337G
Windows xp will not read 8gb sd card
Thats all
2 Suggested Answers
  • 54 Answers
SOURCE: How larrge and SD memory card will it read? can it read an 8GB
1 GB SD card http://www.gpx.com/store/p/186-MW3836.aspx
Posted on Jul 14, 2011
SD card reading
usually means the sd card is corrupted, if its new you may have a fake sd card. ie you buy a 32gb type and its only an 8gb sd card been flash formatted to read it as a 32gb everything past the 8gb will be corrupted. if this is not the case and not new it will be a wan out sd card this can happen if they overheat and its use.
Jan 31, 2018 | Power Acoustik PD-710 7-Inch TouchScreen...
Hi I have 8gb Transcent Micro Sd Card that is encounted a problem when i m downloading using 5130. After that its not opening Its Says that not Formatted. when i insert in to my pc only showed my card...
If there are hidden partitions on the memory card, Windows 7 will not allow you to change the partition. So to format use a PC with windows XP or older. You also could format this card in most camera's. For that place the card in a SD adapter and put it in your camera. Let the camera do the format.
When you put the card back in the phone, make sure you first format the card with the phone software. Just to be sure the phone can read and write the card.
Jan 15, 2014 | SanDisk 8gb Micro Sdhc Memory Card Bundle...
Not getting formate and not opening
Your operating system may be to blame, Windows upto XP and including some early ( pre SP1) will not paly with an external memory card above 4GB. But try it in a different computer first, it may be a faulty chip or reader.
May 04, 2012 | Transcend 8GB microSDHC Class 4 Card with...
Acer Aspire One ZG5 AOA 110-Bb, not booting up / detecting with 8GB SD Card
According to the Acer Support web site the Aspire One cannot boot from a SD card so you will need to give more details of exactly what problem you are having when booting this netbook.
The documentation for the Acer Aspire One AOA110 can be found via this link.
Jan 13, 2012 | Computers & Internet
I just got a PNY Pro SDHC 8 GB for my camera, but my HP computer freezes when I insert it. My computer is a Windows XP Media Computer and reads other cards. Any suggestions?
i know you don't want to hear this but i had a simuliar problem and found out not all sd asswell as other cards are compatable it varies by brand,i would just change brand of cards.that solved my problem.
Aug 29, 2011 | PNY 8GB Secure Digital High Capacity...
Why can't I get pictures off of an 8gb but I can off of a 2gb chip?
Some cameras cant manage/format large size memory cards as they where not made to handle that size. Check your user manual which should tell you the maximum size memory card your camera will take.
Aug 04, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Have a sony vaio notebook that will read a kodak sd card but will not read a transcend sd card. any help would be appreciated
Please check if the Computer supports SD card of larger capacity.
If preinstalled OS is Windows XP Operating System, supports SD card from 512 MB to 2 GB max and does not support SDHC card.
Windows Vista and Windows 7 Computer supports SD and SDHC card upto 8 GB to 16 GB,.
Jun 22, 2010 | Sony Computers & Internet
Unable to open to read micro sd 8gb in window mobile and pc
just try to clan the connector port (bronze part), clean it with eraser and wife it clean. Not 100% solution, but no harm on trying.
If still not working then I suggest get a new one, your memory card might be corrupted
Nov 02, 2009 | SanDisk 2GB microSD Memory Card
Wont read sd card 4 gb
You will have to upgrade your dash to windows 6 if you want it to read higher compacity micro sd cards. This method i free and is the only way their is no unlock code to make the the software compatible, you must upgrade it. once upgraded you can use up to a 8gb micro sd, i have not tried a higher card than that.
Jun 02, 2009 | T-Mobile Dash Smartphone
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
GPX MW3337G Logo
563 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
