Question about Microwave Ovens
Sharp Carousel Convection Microwave Oven Model R-9X55
Does not show temp when checking by pressing convection pad and is shutting down every few minutes.
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave convection heat shuts down
That could be several things, but to me the most likely is that your thermistor is caked with grease - somewhat shorted as opposed to open. By contrast, when the thermistor is open, the classic symptom is that the coolling fan runs more than it should. The other most likely possibilities include the damper motor or switch or control panel. You should be able to get any needed parts at Tritronics at http://www.wehaveparts.com You can find critical safety & disassembly info in the serice manual or at our Web site. We have the actual service manual for that model on our site at http://www.microwavedisplay.com/R930AKAW.pdf (if that URL fails try http://207.234.249.73/mwd/R930AKAW.pdf) Post back if you wish.
Posted on Dec 24, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp Carousel Microwave Convection Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
You may have a bad keypad.
Posted on Sep 16, 2008
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp model R-1871 shuts off every 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
Posted on Aug 30, 2009
Testimonial: "traced to motor for damper. Would not have had a clue without this information provided by fixya"
MicrowaveSvc
  • 9085 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
Microwave has lost all power, what could cause this problem, and how to remedy?
Switch it off from the wall switch for a few minutes , then switch back on this will often reset it . if not get it repaired or replace it. don't open it your self , dangerous voltage inside.
Jul 09, 2015 | Sharp Microwave Ovens
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Jan 25, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
