Question about Liebherr CS2062 Bottom Freezer French Door Refrigerator
Liebherr 7081 432-00 interior light not working
Changed the bulb but the light still doesn't work
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: I have a Liebherr Fridge with an icemaker that
When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the icemaker won't make ice. (Also note that your home's water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn't make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn't arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn't kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism-this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you're skilled at home repairs, this job is better left in the hands of an appliance repairperson.
Check it and keep us updated.
Posted on Jun 29, 2011
Why is my interior light occasionally flash on and off?
Because the interior light on/off switch has developed an intermittent connection. Replace the switch.
May 24, 2016 | Liebherr Refrigerators
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Peugeot boxer van 2007 changed interior light bulb blew fuse, renewed fuse, lights worked, but emissions lights on dash board came on and won't go out. Help
Try reading the OBDII with a code reader and see what it is then erase codes and see if it stays off ,could be more than one circuit on this fuse so the fuse blowing has thrown the light on for whatever reason ,Also try disconnecting the battery just out of interest for a few minutes and reconnect it might go out if your lucky
Feb 27, 2012 | Cars & Trucks
My drivers side brake light doesn't work on my 1992 volvo 240
Check for power at the bulb socket then make sure it has a good ground.
Feb 24, 2012 | 1992 Volvo 240
My drivers side backup light isn't working. I changed the bulb and it still doesn't work. Apparently there isn't a fuse for the backup light. Can anyone help?
If the other one is working then there is something wrong with the wireing between the two of them, or the connection in the light or the bulb contacts are dirty in the holder.
Nov 29, 2011 | 1999 Jeep Grand Cherokee
1997 Acura 3.5 RL right brake light not working (all other rear lights - both left and right work). Changed bulb (two separate bulbs) and still not working. Checked all fuses under dash and hood. Is...
The problem is the socket. Remove the bulb and bend the tabs in the socket so they make contact with the bulb. If this doesn't work you will have to replace the socket. A wire is broke and they usually break at or in the plug.
Jul 19, 2011 | 1997 Acura RL
Rear registration light doesn't work ...have changed bulbs and fuses still not work...
Could be just a bad connection. Check it for voltage with your lights on. If you get 12V, your connection is probably either weak or oxidized. You could try bending the connector wires out a little if it's a plug-in type bulb, or cleaning the socket if it is a socket type bulb. It helps to use some dielectric grease on the bulb/receptacle as a preventative measure against corrosion.
Jun 23, 2011 | Ford Focus Cars & Trucks
I need the wiring diagram for lights in the living space. the lights in the living room don't work. the bulbs are new
Are you talking about a camper that is mounted in the truck bed? A truck doesn't have a living room. If your talking about the interior light check you dash board light dimmer control to make sure it hasn't been turned off.
May 15, 2011 | 1984 Ford F 350
Liebherr CS2062 Bottom Freezer French Door Refrigerator Logo
143 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
