Question about Eaton Fuller Roadranger Transmission Ta-d67-11x Fr-9210b 10-spd
My trans ECM is throwing these codes, MID 130, PID 60, FMI 10. Please help!
It just started today, my driver info screen says to check trans ecm next stop
2009 cummins isx cm871 fualt code mid 128 sid 372 fmi 1
[PDF]Fault codes .pdf - heavydutypowertrain.Com
www.heavydutypowertrain.com/md200codes.pdf
Description. Sample Fault Code Chart. Sample Display. 128. PID/SID FMI. MID. 110. 003 ... MID 128 - CAT. CAT. PID/. SID. FMI Fault. Code. Fault. Description. 1. 11. 72..... Injector Metering Rail #1. Cummins (Continued). PID/. SID. FMI Fault. Code ...372. Fuel Pump Control Module. 12. 374. Fuel Pump Control Module. 13.
2009 Volvo ISX Cummings Codes ' TruckersReport.com Trucking Forum ...
www.thetruckersreport.com > ... > Volvo Forum
Sep 13, 2013 - Well my truck finally stopped today and has these 6 codes. Anyone have any idea what they are? MID 128 SID 380 FMI 11 MID 128 PID 131 ...
[PDF]Diagnostic Fault Codes For Cummins Engines - Allied ...
www.alliedsystems.com/pdf/Wagner/Forms/80/80-1044.pdf
Dec 18, 2015 | Cummins Signature ISX QSX15 Series Service...
I have a Volvo 670 2007 D12 and I keep getting fault codes ECU Maintenance MID 128 PID 27 FMI 5 and MID 128 PID 245 FMI 9. Does anyone know what they mean?
These code are specific to Volvo and you will probably need to contact a Volvo service department to have them explained.
Aug 23, 2013 | Cars & Trucks
Check engine light on but no codes
The check engine light will come on when the ECM detects knock, it will only stay on if excessive knock is detected. I would replace the fuel filter and check your fuel pressure.
Could also be a bad knock sensor as the ECM will also advance the timing to make the engine knock. If on knock is detected when the ECM is doing this it will light the check engine light.
Apr 18, 2017 | 1987 Chevrolet Suburban
Vt 275 ICP issues
That sounds like a bad spot in the throttle position sensor. Have you checked that, or substituted a new one for it?
Apr 19, 2017 | Cars & Trucks
Vt 275 ICP issues
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Sep 19, 2012 | Cars & Trucks
I have 05 volvo vnl 670, isx cummins 450/500. keeps losing power, check engine ECU comes on knowbody seems to know what it is. they just keep replacing sensors.
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
Feb 16, 2010 | 2005 Volvo XC90
Eaton Fuller Roadranger Transmission Ta-d67-11x Fr-9210b 10-spd Logo
485 people viewed this question
Top Eaton Plumbing Experts
Donni Steen
Tom Chichester
Are you an Eaton Plumbing Expert? Answer questions, earn points and help others
