Question about Pioneer PureVision Pro-800HD 43 in. Plasma HDTV
TV does not turn on
I own a Pioneer PRO 800HD and while turning the TV on three days ago, I hear a crack and the TV shut off. I unplugged the TV and attempted to turn it on again but still nothing. On the bottom left corner of the frame, the TV is blinking red 5 times and a 2 second delay before it blinks again. Do you have any idea what's happening. The TV is approx. 2 years old. Thanks for your help! Keith Exact same problem here! Any solution yet, thanks Hans
  • spyder550 Jan 11, 2009
    where are these boards located and how do you "check them"
    Thanks
    Hans
  • spyder550 Jan 12, 2009
    If it is the power supply, how come the light still blinks ?
    Thanks
    Hans
  • 728 Answers
The crack you heard was most likely a blown fuse or a blown capacitor. The reason the LED light still blinks even though one of those may have been blown is because it is like giving you a code for you to identify the problem so that you can check it and repair it. If you know how to do it yourself, on the main power board, you will see 1+ glass tubes that have metal on the ends and on the insides. If the metal on the inside is broken apart, or if the glass it self is broken, then that fuse need to be replaced.
Posted on Jan 12, 2009
  • 4,234 Answers
To resolve this, first follow the link provided by abhishek33 as Pioneer apparently has a no-charge fix for this. Second, in answer to your question about the blinking, this is what is happening:
When the set is plugged in, there is a power supply that is always on. This is called the "standby" power supply. This provides 5V to give power to the internal CPU (computer) and the remote receiver circuit. This is what allows you to use a remote to turn on the set. When the set is turned on, there are a number of circuits that check for proper function and will shutdown the set if problems are detected. This is to minimize further damage. Those circuits also cause the standby light to blink a counted number of blinks. This will indicate the circuit that detected the problem which will then speed up the diagnosis and repair process. This is not unique to these sets but exists in many manufacturer's products.
Hope this helps,
Dan
  • 2,071 Answers
Open the unit then go to power supply section check the fuse if its open ,check also the diode,capacitor and regulator transistor for open also if defected replaced it with the identical ratings.Thats is the common components parts easly damaged in power supply causing not turn on.Maybe also has a loose or cold soldered joints that caused a crack sound You better resoldered all parts joint in power supply section.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 11, 2009
  • Pioneer Master
  • 19,396 Answers
If a pioneer plasma blinks 5 times it means:
Standby LED blinks 5 times. Burned components in PSU.
When this happen the technician perform several test (check capacitors, read voltages, read continuity on resistors) on the PSU unit (the power board), then replaces the faulty component or the whole board.
I think all people here that are telling you to replace the whole board do not have a clue of how the board is done and how much it can cost.
A PSU board for this set is expensive, and therefore it is better to call a technician that can test a replace the broken component, often a $1 capacitor.
Here is the replacement power board for your model: AXX1064 , the cost is over $400.
    Genius:
  • 1,239 Answers
Hi
7 blink error on that model is 8.6 volt error and generally caused by y main board. disconnect y main from power supply and if tv does not shut down and vs voltage comes up (test point on power supply) replace y main and both y upper and lower buffer boards as replacing one without other two could cause additional failures
Posted on Jan 10, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 10, 2009
    2 blinks means the unit is having problem with 12 volt supply.
    while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board..
    I'll need to verify this for your specific model, but usually the 6 blinks means that there is nohorizontal pulse. The 7 indicate a high voltage shutdown. Since the symptom changes, I would look first for poor solder connections in the horizontal circuit. Can you solder? If so, update this and I'll try to provide more details.
    if not solved These sets usually need crt change
    Sergeant:
    Novelist:
  • 326 Answers
This requires a replacement of the power supply board.
you can get the required board at the pioneer service center or at
www.partstore.com
just select the proper model and brand and get the required part.
thanks.
  • 89 Answers
This requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
    Sergeant:
  • 378 Answers
Five Blinks---- AKB circuit (AKB), the timer/ standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board. Also check Q218, 219, 220 on the A board. Also, unit can be in IK blanking. Try turning up screen slightly.
    President:
  • 2,110 Answers
  • Sibananda Jena
    Sibananda Jena Jan 10, 2009
    http://www.pioneerelectronics.com/PUSA/S...
    Important: Updated Information Regarding Free Power Supply Replacement
    for Certain Pioneer Plasmas
    Pioneer is continuing to offer a free, in-home/office power supply
    replacement for certain of its second and third generation plasma
    models listed below for customers who experience a problem with the
    original power supply. If a model is not listed below, no power supply
    replacement is needed and no further action needs to be taken.
    If you own or use a plasma listed below, please call our toll free
    hotline at 1-800-421-1404 to arrange a time to have your plasma's power
    supply upgraded at your residence or office at no charge.
    Plasma Models (15 listed):
    • PDP-505HD
    • PDP-503PU
    • PDP-5030HD
    • PDP-5031HD
    • PDP-433PU
    • PDP-4300
    • PDP-4310
    • PDP-4330HD
    • PRO-800HD
    • PRO-800HDI
    • PRO-1000HD
    • PRO-1000HDI
    • PDP-433CMX
    • PDP-502MX
    • PDP-503CMX
    The issue with the power supply in the plasmas listed above does not
    pose any health or safety risk. Pioneer has received reports that the
    power supply in the affected models may fail. In some cases, a loud
    popping sound can be heard when a power supply fails. After the power
    supply fails, the plasma is no longer operable.
    Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
    We apologize for any inconvenience.
    Sergeant:
  • 431 Answers
Check the power cable
  • nematics
    nematics Jan 10, 2009
    I guess the fuse would have gone due to excessive power input. Did you use a stabiliser to conenct or you conencted it directly??
I have the Pioneer PDP5010fd. TV has worked great since buying in 2007. Two days ago we came back from vacation and the blue light was just blinking. It blinks 12 times and then starts over. The TV...
Most likely yes power supply need repairing or replacing, find a cheaper repairer it should only be $150 max as the repair kit would only cost around $30.
Mar 24, 2017 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
I have a PDP505CMX 50" pioneer flat screen. the picture shut down recently and the standby light blinks red. any idea about what is going on here?
i would say a power supply issue or maybe the Y SUSTAIN board, Check for swollen capacitors in the power supply, Test the voltages on the VA AND VS lines are there if so its more than likely your Y Sustain board.
Hope this helps
Mar 05, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
We have a pioneer plasma tv and there was a loud popping sound and then the screen went blank
I had the same thing happen a few weeks ago to my zenith 50" plasma tv. I tried to turn it back on with the remote and the power button on the set but the only thing that happened was the led would flash green 3 times and then go back to red. I took it to a repair shop and they called yesterday to tell me it was going to cost $700 to fix it by replacing the power supply. No guarantees either that it will last any longer than the 3 years I've had it for either. But it's still cheaper than replacing it with a new "bigger" tv which is what I will eventually do anyway. I've heard of people looking on ebay for repair parts and doing the repairs themselves but there is no warranty on human error...
Nov 05, 2009 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Aug 21, 2008 | Pioneer PRO-99 TV
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PureVision Pro-800HD 43 in. Plasma HDTV Logo
458 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
