Question about JVC GR-D270 Mini DV Digital Camcorder
Removing dv cassettes manually
My camcorder is dead and can't be powered up, even when connected to the AC power adapter. tapes won't eject as a result of the lack of power, and I need to find how to manually eject the DV cassette in the camcorder.
  • Anonymous Mar 23, 2014
    door opens but cassette will not eject
  • 883 Answers
Open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Posted on Jun 06, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Sony trv25 cassette does not eject
These can have ls chassis failure causing the tapes to jam in the set. Can be repaired under $200 in most cases. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Apr 22, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
The camcorder casset is stuck in the eject position. reset does nothing for the problem.
for tape loading issues,do a power reset procedure. make sure ac adapter is not connected.set cam to off position.remove the battery and leave the camera without power for at least a minute.use the ac adapter and turn cam on.see if this resolves it.if not...service is required.
Mar 12, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
Cassette won't eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 13, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Can't open the dv tape
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Sep 16, 2007 | Canon MV850i Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
830 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
