Question about Microsoft Computers & Internet
Firmware de la lectora de LG GH10L DVD-R/RW - Microsoft Computers & Internet
  • 619 Answers
SOURCE: cd rom et lecteur cd dvd ne fonctionent pas
Hi , you may puchase nero express 6 cd -dvd burner driver or visit : Computer TitanFacts.net
Posted on May 14, 2008
SOURCE: HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Posted on Dec 29, 2008
SOURCE: LG dvd/cd-RW drive not reasd dvd bt read cd .help
i found when u burn too many cd,s on a dvd burner it stops burning dvd,s is this why ? buy a new one if its still new get ur money bk buy a different model : )
Posted on Apr 27, 2010
shibuda
  • 1812 Answers
SOURCE: Dear Mr. Assistance, I have uninstall
If you use xp can roll back the driver,
Follow bellow the link,
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx
Hope this helps,
Posted on Jan 23, 2011
bronk50
  • 27725 Answers
SOURCE: I have an LG GH24NS50 DVD RW and I added another
make sure that the dvd-rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Feb 06, 2011
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Hola mi lectora no lee los CD?,
Haga clic en iniciar el control de las herramientas administrive panel, administraci?n de equipos, administrador de dispositivos, despl?cese hacia abajo cd-dvd rom unidades puede ver un signo de interrogaci?n amarillo? bot?n derecho del rat?n tendr? opciones para actualizaci?n del controlador, Volver al controlador anterior o seleccione las propiedades generales de solucionar problemas, seleccione el controlador, haga clic para volver a instalar los controladores de clic en Actualizar controlador o desinstalar y reinstalar, si esto no soluciona el problema puede ser que sea un problema del registro si no puede ver su unidad de disco en el Explorador de Windows
Cierre todos los programas
Haga clic en Inicio, Ejecutar y escriba regedit y oprima
Haga clic en el signo m?s (+) junto a las carpetas siguientes
HKEY_LOCAL_MACHINE
SISTEMA
CurrentControlSet
control
clase
Esta carpeta es el reproductor de DVD / CD-ROM Descripci?n de unidad de clase en el registro. Busque cualquiera de los siguientes nombres en la columna de la derecha.
Filtros de alta
Filtros de baja
superior Filters.bak
menor Filters.bak
Si alguna de las teclas de arriba se muestra en el paso 4 en la lista, haga clic derecho sobre ellos y elija Eliminar Despu?s de eliminar las teclas, cierre el editor del registro
Reinicie su computadora
Abra Mi PC y compruebe si su unidad de CD o DVD han regresado. Tambi?n es posible que desee abrir el Administrador de dispositivos y verifique que el signo de exclamaci?n amarillo y el c?digo de error en la unidad de CD o DVD se ha ido. o
puede que tenga que desconectar f?sicamente los cables de este cd / dvd luego enchufe de nuevo este debe activar el Asistente para hardware nuevo o
puede que tenga que desinstalar y reiniciar el equipo vuelva a instalar el reproductor de DVD / CD vuelva a instalar el controlador de este dispositivo
Si el equipo viene con un disco de la placa base los controladores podr?an estar en ella
haga clic en Inicio, Panel de control de las herramientas inform?ticas de gesti?n administrive administrador de dispositivos, despl?cese hacia abajo cd discos DVD-ROM si usted ve una cuesti?n de color amarillo o signo de exclamaci?n? ! o una X roja, haga clic derecho tendr? que actualizar el controlador o
Sep 09, 2011 | LG CRD 8521B Internal 52x CD-ROM Drive
Hola, mi quemador dvd modelo GH22NP21 no me quema los dvd porque? los cd si los quema, pero los dvd no. tengo windows xp sp2 con 248 ram, lee el dvd y guada la imagen en disco duro al momento de insertar...
Los quemadores de DVD cuentan con dos unidades de laser. Un laser es para quemar y leer discos DVD. El otro es para leer discos CD. Es muy común que el uno o el otro falla. Si el aparato todavía está bajo la garantía, puede Ud. pedirles quemador nuevo. Si no, tal vez haya llegado la hora de comprar un nuevo. Lo bueno es ya no cuestan mucho... meno de $30 por quemador de buena marca.
Mar 14, 2011 | LG GH22NP21 DVD-Writer - Internal...
Tengo un LG dvd-ram gsa-e60L usb device que no reproduce peliculas originales ni con el ciberlink powerdvd
DESCARGA ESTE MEDIA PLAYER CODECS PACKDALE CLICK AQUI
DALE CLICK EN EL LINK QUE DISE CLICK HERE TO DOWNLOAD EN LA ESQUINA HIZQUIERDA DE ARRIVA, E INSTALA EL PROGRAMA , PODRAS TOCAR TUS DVDS EN WINDOWS MEDIA PLAYER
Feb 17, 2011 | LG GSA-E60L 20x DVD?┬▒RW USB 2.0 External...
Hola: tengo problemas con mi portable super multi driver LG GP08NU6B, ya que mi Pc no lo reconoce, cuento con el windows 7; y pienso que el problema es por que ya tenia antes instalado otro lector de...
A mi me ocurre exactamente lo mismo, en una netbook donde no tenía ninguna grabadora instalada funciona ok, pero en la pc de escritorio o en la notebook no funciona, todas tienen windows 7. El soporte telefonico o via mail de LG me mandan a la tienda donde la compré...!!!! Es raro,le busque varias soluciones pero no logro hacerla funcionar!!!
Jan 23, 2011 | LG GP08NU6B DVDWriter Black External...
My GSA 2166D does not recognize dvds when I insert into drive, it will recognize and burn to cds is this a lens or driver issue? The program that I go though tells me that there in not a disk. I tried a...
Hi As your drive is burning cds but wont burn dvds, I suggest your try other brands of dvds and a different burning program.I use Ashampoo Burning Studio 6 FREE, which you can down load free from the web.Hope this helps you.
Regards Bill
May 15, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
Pc lenta
Los problemas en tus maquinas son de virus y conflictos de software. En el caso de la # 1 es posible que este lenta por problemas de hardware, pero si decis que en las otras hay troyanos es muy posible que toda la red este infectada. Los troyanos la unica manera de erradicarlos definitivamente es formateando las maquinas y reinstalando todo de nuevo. (Los antivirus por mas efectivos que sean no sacan este tipo de problemas y a la larga terminas reinstalando todo de nuevo) Te recomiendo hacer un respaldo de todos tus archivos, y reinstalar todo desde cero.
Sep 24, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Sony dvd try problem
Cambiale la banda del motor de carga se encuentra debajo de la charola del disco con ella abierta la puedes ver.Espero esto te ayude.
Mar 29, 2008 | Sony DRU-810A DVD RW Dual Layer Burner
Computers & Internet Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
