Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Phillips Whirlpool Ultimate Care II won't spin very quickly
I have a Phillips Whirlpool Ultimate Care II which is about three years old and works ok except that it does not seem to spin as quickly on fast spin as it once did.I have checked the verticality and checked for obstructions in the drain from the bottom of the drum onwards. Anything else I should try?
  • 530 Answers
If this is a top loader it is possible that you have a bad clutch. sometime when your transmission leaks oil it will get into the clutch and this will cause a slower spin and possibly no spin. Tip the washer back just enough so you can see under the washer. Is there a orange/yellow sticky substance under there? If so this is trany fluid.
Posted on Jan 12, 2009
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Whirlpool ultimate care ii won't spin
Possible that the drive is jammed , there is slipping or the motor is faulty. You need to check for free movement after disconnecting the power, if there is friction it must be reset.
Jan 21, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care will not stop spinning
I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
Hope this helps _MJ_
Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Super Capacity Plus
BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II wont spin,
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
197 people viewed this question
Dan Webster
Dan Webster
Sal De
