Question about Brother MFC-440CN InkJet Printer
Brother mfc - 295 cn F4 Print Head Error - Brother MFC-440CN InkJet Printer
  • 186 Answers
SOURCE: installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Posted on Dec 09, 2007
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
Brother mfc - 295 cn 46 unit unable not printing
Clive's solution worked partially on my MFC295CN. i further erased the number of cleaining cycles and the error message code in the same maintenance mode and it worked. thank you all
Nov 15, 2011 | Brother MFC-440CN InkJet Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer
Paul,
did you had a paperjam the days before?
The encoder strip which gives the print head the position is out of position. It has to be fixed into the ph.
Read my post here (same issue and same procedure):
http://www.fixya.com/support/t272288-unable_print
Dec 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-440CN InkJet Printer Logo
76 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
