Question about KitchenAid KGRT607 Gas Kitchen Range
I have a Kitchenaide KGRT607HWH6 the oven gets up to temperature and then displays the F7:E0 code and shuts down What is this error code?
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
The error code "F7:E0" means "Invalid latch switch reading".
The first thing I would do is check the interlock switch on the door latch and the door latch itself (the door latch assembly is located on the back of the range). The interlock switch must be closed when the door is locked.
If there is nothing wrong, then check the wires from the switch to the control board.
If wires are fine then replace the control board.
Here is the interlock switch
Here is the oven lock assembly
Here is the control board
Posted on Nov 30, 2012
  • Ty Roshdy Dec 02, 2012
    Hi Thanks for answering my question. I will be ordering the part and hope that it works. As soon as I get back to the stove and check it out I will get back
localwonder
  • 6784 Answers
SOURCE: f7:eo error
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Nov 03, 2009
SOURCE: Error F7:E0 on Kitchenaid range
http://servicetechhelp.com/Docs/2603.html
Posted on Sep 14, 2008
Treefrog15
  • 127 Answers
SOURCE: ERROR CODE # F6E1 displays and shuts down oven
F6-E1 - Return Line Not Connected - Replace control board (clock).
Posted on Dec 23, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kitchenaid Oven won't work E0 F2 on the control pad
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: KitchenAid KGRT607HWH6 temperture, light, error code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    Tip
    Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
    Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
    WHIRLPOOL - most models
    Range/Stove and Oven Fault Codes, Common error codes.
    F1 - Analog control board Failure
    Disconnect for one minute - if error comes back, replace control board
    F1 - Shorted control keypad
    Replace keypad
    F3 - Oven temperature sensor open
    Replace oven temperature probe
    F2 - Oven temperature sensor shorted
    F3 - Oven too hot
    F3 - Clean temperature too hot
    Replace oven probe
    F5 - Door latch switch fault
    Test and replace the door switch.
    Whirlpool with 4 Digit Failure Code:
    F1 - E1 - Electronic control (flip flop)
    F2 - E0 - Shorted control keypad
    Replace keypad
    F3 - E0 - Oven temperature probe open
    Replace temperature probe
    F3 - E1 - Oven temperature probe shorted
    F3 - E2 - Oven temp too high
    F3 - E3 - Clean temp too hot
    Replace temp. probe
    F5 - E0 - Check door latch
    F5 - E1 - Check door latch
    Replace switch if defective
    WHIRLPOOL Polara models 5 digit codes:
    F1 F0 - EEPROM communication error
    Replace ERC
    F1 E1 - EEPROM checksum error
    Replace ERC
    F1 E2:7 - UL A/D errors
    Replace ERC
    F1 E4:2 - Model ID error
    Reinsert keytail.
    F1 E6:0 - Latch signal mismatch error
    Replace ERC
    F2 E0:4 - Shorted key error
    Replace keypad assembly
    F2 E1:3 Keytail unplugged
    reinsert the keytail
    F3 E0:5 Top oven sensor open
    Test and replace top probe.
    F3 E1:6 Top oven shorted
    Test and replace temp probe
    F3 E2:9 Bake range over temperature
    F3 E3:8 Clean range over temperature
    Test and replace temp probe.
    F3 E4:10 Bottom oven sensor open
    F3 E:15 Bottom oven sensor shorted
    F5 E0:14 Door switch errot
    Test and eventually replace door lock switch
    F5 E1:16 Door latch not operating
    Test and eventually replace door latch
    F8 E0:17 Refrigeration error
    Test the cooling module.
    PF Power failure - Does not indicate a fault.
    PF occurs when power is disconnected.
    WHIRLPOOL
    Models SF3, 30'' and 24"
    F2 - Oven temperature above specifications
    Check 8-pin connector from temp. probe to Electronic Oven Control
    F3 - Open oven temperature probe failure
    Check wiring, replace oven probe if necessary
    F4 - Shorted oven temperature sensor failure
    Check wiring harness, replace oven temperature probe if necessary
    F5 - Push button stuck or faulty
    Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
    F6 - Electronic control logic error (timing)
    Replace Electronic Range Control (ERC)
    F7 - Electronic control logic error (lock motor)
    Replace ERC.
    F8 - Electronic control logic error
    Replace ERC.
    on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
    The oven isn't working and it says FO in red letters
    GE / Hotpoint / RCA
    Oven Fault Codes
    Display Condition Remedy
    F0 & F1 Failed Thermistor Control Replace ERC
    F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
    F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
    F4 Shorted wire or Sensor locate short and correct it
    F7-A Function pad button stuck Clean and unstick
    F7-B Bad Clock Replace Clock
    F8 Electrical component failure Replace ERC
    F9 Program with door circuit Check wiring
    Frigidaire / Westinghouse / Tappan / Gibson
    Oven Fault Codes
    F0 & F1 EOC failure Replace EOC
    F2 Oven over heat Defective Sensor or EOC
    F3 Oven Sensor Open Replace Sensor
    F5 EOC failure Replace EOC
    F6 EOC failure Replace EOC
    F7 EOC failure Replace EOC
    Maytag / MAYCOR / Magic Chef / Jennair / Admiral
    Oven Fault Codes
    F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
    F2 Oven over heat defective Relay Board or (if present) or defective Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Hardware, safety circuits disagree Replace Clock
    F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
    F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F8 A/D Warning Replace Clock
    F9 Door Lock Warning Check door lock circuit or Replace Clock
    Amana / Caloric
    Oven Fault Codes
    Type with display - glass link ERC
    F0 No Safety Signal Replace adapter board
    F1 No Safety Signal Replace ERC
    F2 Oven over heat Replace defective Sensor
    F7 Shorted Touch Panel Replace Glass Panel
    F9 Door Latch Error Check latch
    FF Lock Error Check switch and motor
    ERC III - Relay board with separate board/push buttons
    F0 Shorted Push Pad Replace Push Pad
    F1 Defective ERC Replace ERC
    F3 Oven Sensor Open Check/Replace Sensor
    F5 Defective ERC Replace ERC
    F6 Defective ERC Replace ERC
    F7 Shorted or sticking button Clean button or replace touch pad
    F8 Defective ERC Replace ERC
    The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
    Whirlpool / KitchenAid / Roper
    Oven Fault Codes
    Ovens with 4 digit displays
    F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    Ovens with 2 Digit Displays
    F0 Defective ERC Replace ERC
    F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
    F7 Shorted or sticking button Clean button or replace ERC
    F9 Door Latch Error Check latch and latch circuit
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Dec 18, 2009 | Ovens
    Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
    It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
    Note: Applies to all F3-E... codes.
    From KitchenAid themselves
    F3 E0
    Get one from the people in the first video. Very easy fix.
    https://www.youtube.com/watch?v=VZKHpduF9RI
    kitchenaid oven temperature sensor replacement Google Search
    Sep 17, 2009 | KitchenAid Ovens
    F2e0 error on stove
    Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
    --> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
    Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
    Dec 22, 2007 | KitchenAid KGRT607 Gas Kitchen Range
    KitchenAid KGRT607 Gas Kitchen Range Logo
    625 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
