Question about Gateway MX6453 Notebook
Gateway mx6453 won't start up - Gateway MX6453 Notebook
  • bobbies2836 Jan 19, 2009
    The Gateway MX6453 PC Notebook that I'm trying to boot up, shows NO display. I tried connecting it to an external monitor, using Fn F4 to tell it to go to that monitor, but still nothing.
    The hard drive indicator is light and the fan is running. The "ON" button has a backlight in blue, and that is on. Tapping the On button does nothing - I have to hold it down to turn everything off - acting like it has Windows loaded.
    Is this possibly a BIOS problem?
    Bobbie Seabot
    bobbie2836@gmail.com
  • chrisvenegas Jan 31, 2009
    i was in the middle of a powerpoint slideshow when my screen went white. i wasnt able to use my keyboard so i turned my laptop off. when i turned it back on, i had the same problemn as you. i looked around at user forums and the best answer i have found is that the video chip is fried and that the only thing we can do is replace the entire motherboard. im wondering if replacing the motherboard will bring back my laptop exactly as it was before. i am very afraid of losing my files and software. i have a gateway mx6448.
    Scholar:
  • 118 Answers
I would say that the problem is with the video card, and yes, you may need to replace entire mainboard. Check your warranty period, if it is still valid, just go to service center to get it fix, no need to ask around.
When replacing mainboard, your files, softwares and settings is still in place. Unless you also replace the hard drive, you will have the computer back as is used to.
Posted on Feb 02, 2009
4 Suggested Answers
SOURCE:
rulds2008
  • 3866 Answers
SOURCE: Gateway MX6453 fan does not start until 70 degress celsius
This would be due to a faulty sensor if it does not reboot and overheat then leave it be and buy a cpu cooler that goes underneathe the unit there around 20 bucks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 14, 2009
  • 10406 Answers
SOURCE: gateway mx6453 wont boot up- oper system not found
Were you having problems with the disk-drive?
Insert the "System Restore" disk into the CD-drive.
Restart the computer, and press DELETE to enter BIOS SETUP.
Change the "boot order", to make the CD-ROM the _first_ boot-device,
demoting the disk-drive to the _second_ boot-device.
Save the change, and restart the computer.
It will boot from the CD-drive, and you can choose to reinstall Windows or to start the "Windows Repair" task. First, try the "repair" option.
Posted on Nov 27, 2009
jepito
  • 216 Answers
SOURCE: Gateway MX6453 overheated and won't power-up.
do this in my shop i have a automotive air compressor - if you dont have one take it to a tire shop blow air in from the back of the computer in reverse order if you have a jacked up computer or blocked fan do this .... i blow out on average 12 computers a day .... with a compressor i purchased for under 80 bucks at wakmart ;()
Posted on Dec 27, 2009
Hey, i recently reformatted my mx6453 so im back to the old win xp sp2. reinstalled all my drivers but for some reason it won't recognize an internet connection of any kind. at first i though it w
If your driver are ok then is your computer is in same WORKGROUP like other are(If you are in LAN connection and sharing internet with other).
was there any IP address in your computer before you formatted it? make it confirm and if IP was there then give back the IP to tour connection.
Aug 08, 2012 | Gateway MX6453 Notebook
Audio
Ok you need to download new audio driver for your laptop,,make sure driver for the windows you are runing on your laptop,,you should be able to get driver from the gateway website,,jus searchonline,,like ,,download audio driver for gateway mx6453,,and then windows xp,,or vista,,7,,or which ever one you have on there,,,goodluck
Nov 09, 2010 | Gateway MX6453 Notebook
Where is the location of the wireless switch on Gateway mx6453?
Hi There,
Your notebook does not have a physical wireless switch. However, holding down the fn key (lower left of keyboard) and pressing the F2 key will turn your wireless on and off. Below is the link to your online Manual.
http://support.gateway.com/s/Manuals/Mobile/8513205.pdf
Cheers.
Sep 09, 2010 | Gateway MX6453 Notebook
Jun 14, 2009 | Gateway MX6453 Notebook
How to open case for an mx6453 gateway laptop
Detailed post with photos. Same problem, different model; but it looks the same and other users said it worked for them. Read all the user comments first to see where other people had problems and maybe messed their computer up worse.
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Also, check these two sites for gateway's info on how to remove the keyboard:
http://support.gateway.com/s/Mobile/Q106/Blade/8511369.pdf
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Mar 29, 2009 | Gateway MX6453 Notebook
How to open an gateway mx6453 laptop to get to the motherboard need a step by step.
I haven't done it, but try here:
Mar 28, 2009 | Gateway MX6453 Notebook
Gateway MX6453 power pin problem
http://shop.ebay.com/items/?_nkw=Gateway+MX6453+dc+power+jack
Any of those should be fine.
Mar 24, 2009 | Gateway MX6453 Notebook
Laptop wont power on
Your RAM may be faulty or not making proper electrical connection.
Try reseating your RAM (memory module/s).
Dec 27, 2008 | Gateway MX6453 Notebook
Gateway MX6453 Notebook Logo
450 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
