Question about Cuisinart DCG-12BC Electric Blades Grinder
Won't grind after a week's use.
I just purchased my second DCG-12BC grinder in the last 3 weeks. The first stopped working (just died) after about 3 uses and I exchanged it for the samne product because of its large capacity and hoping the first was just a lemon. Same thing happened again mid-grind after I tapped it on the side (quite gently) to loosen beans at the bottom of the cup.
What's wrong? Can I fix this problem or do I need to return it?
  • Anonymous Jan 25, 2009
    Hi - I received the grinder as Christmas present -- used 3 times and now will not work at all -- I cannot find box to even try to return to store - any suggestions?
  • Martha Samson Feb 04, 2012
    Call 1-800-726-0190 and they will send you a new grinder, although you will have to pay for shipping for the new grinder $4 and to send the old one back. Still less expensive than buying a new one. I just hope my new grinder doesn't have the same old problem!
It's possible that it's not a motor problem, but a switch problem. I dissassembled mine, and am debating replacing the switch. I would try a multimeter, but the safety interlock is a pain.
So I might just rewire it (very easy to do!) so that it runs the minute it's plugged in, and stops when unplugged. I'll post again after I decide what to do.
Posted on Nov 20, 2009
Looks like it is the load side winding, i opened it up and the switch ohmed fine but i lose coductivity when i try and trace to the motor leads. I checked for a safety limit switch but found none. By the looks of everyone else with this problem it is just a poor manufacture.
Posted on Dec 24, 2009
I had the same problem with the grinder - stopped working after about 2 months. i called Cuisineart and they replaced it for warranty, eventhough i had to pay the shipping charges both ways.
Posted on Feb 03, 2009
My Cuisanart coffee grinder does not work (no power) after only a couple of months
you have to make sure the lid is securly in place for safety it will not power on if not correctly lined up and secure.
Oct 08, 2014 | Cuisinart DCG-12BC Grind Central Coffee...
Stopped working. Does it have any fuse to replace?
no fuse to replace, if the power cord failed you can contact cuisineart for assistance in getting a replacement unit if under warranty
Sep 14, 2014 | Cuisinart DCG-12BC Electric Blades Grinder
I have Cuisinart Grind Central DCG-12BC.Yesterday it suddenly stopped working.I opened it,but I cannot find anything wrong in it.?
1) test the power cord for open or break with VOM
2) test the outlet box wall, put some another devices and see if working , if does the problem is the device
3) test the main switch for open or defective or loose wires, repair or replace
4) test for thermal fuse inside, for open and replace, see if your model hast c.breaker and reset it.
5) Try now.
6) Please read your owner manual, if you do not have download from www.retrevo.com and go the section troubleshooting
God bless you
Aug 01, 2012 | Cuisinart Grind Central DCG-12BC Blades...
My Cuisinart DCG-12BC coffee grinder, the bowl is stuck on the motor base. It works and turns, but it will not come apart to be able to clean it. Please advise.
.... mine stuck after "first" use ... solution ... took it back to the store, got a refund, bought a Mr. Coffee Model IDS77 which was $11. cheaper, has automatic grind settings and a superior bowl arrangement... Then I put Cuisinart on my list of DO NOT BUY ... anything can have problems, but something obviously this chronic should be handled better by the manufacturer ... it should have been taken off the market and fixed ...
Aug 27, 2011 | Cuisinart DCG-12BC Electric Blades Grinder
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
How to program to automatic brew
For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Need help using my coffee maker
Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
Dec 25, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart DCG-12BC Electric Blades Grinder Logo
576 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
