Question about HP LaserJet Office Equipment & Supplies
How to print borderless on HP cm6040 - LaserJet HP Office Equipment & Supplies
  • 26 Answers
SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Posted on Jun 11, 2008
SOURCE: HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Posted on Feb 05, 2009
anujbhatt
  • 66 Answers
SOURCE: how to print borderless 5 x 7 pictures using an HP
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Posted on Dec 11, 2009
steve_e_uk
  • 1675 Answers
SOURCE: Borderless Printing Doesn't Happen
hi as you have set border less printing in publisher and on printer, have you adjusted the layout guides? on the blank page go to arrange, then to layout guides, adjust the numbers to atleast 0.25 (lowest it will go) and save then try printing, the but remember, hp still has a border due to the print heads position they do not travel over the print area like some printers do, you will always get a small white line no matter what...hope this helps
Posted on May 24, 2010
  • 65 Answers
SOURCE: Is it possible to print
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=4157334&prodTypeId=18972&prodSeriesId=4157434&swLang=8&taskId=135&swEnvOID=1093
The above link will take you to the latest software and driver download for Windows 7. In general most digital printers do not print border-less. There are some out there that will. There is mostly a white border that surrounds your print document in the digital world. Ive read through your printers documentations and didn't see any options for a border-less print. I hope this answers your question.
Thank you,
Posted on Jul 05, 2011
HP Color Laserjet CM6040 only prints in black and Cyan no yellow or magenta ?
Have they printed 21,000 pages yet, or 10 reams of paper?
Check in the Printer Settings under Maintenance for clues and run the Tests and Maintenance steps.
HP Color Laserjet CM6040 Google Search
Mar 14, 2017 | HP Office Equipment & Supplies
Error 49.4C02 on cm6040 mfp
Replaced formatter ,disk drive plus memory card .problem solves
Nov 30, 2011 | Office Equipment & Supplies
Teardrop shaped light flashing on hp 5650
Hello Sgaetjens,
The tear drop shape LED is called the print catridge LED indicator. If you do see this light flashing it means that there is an issue with one or both of the cartridges. This issue can occur for the following reasons:
  • One or both cartridges might be incompatible with the product.
  • One or both cartridges might be improperly inserted.
  • The borderless printing settings require adjustments.
For the first,two I suggest that you verify that it is indeed HP original cartridge and not just replacement ones that you can purchase anywhere. Remove and reseat the ink cartridges carefully. With regards to borderless printing, go to Control Panel and then Printers and open up your HP Printer and then check the properties and defaults. Normally it is under Printing Shortcuts where you could find Borderless Printing.
Jul 22, 2011 | HP DeskJet 5650 InkJet Printer
Will it print from edge to edge on the paper?
Most will not, at least not with the drivers that the manufacturers give you.The only time I have had a printer print edge to edge is when I got my Windows Mobile 6 phone to print via bluetooth to an HP printer that came with a bluetooth dongle. I could not get that same printer to print edge to edge when printing from a computer, no matter what I did.
Here is some more advice regarding HP printers (since you didn't specify which printer make or model, and HP is the most popular):
from: How to Print to the Edge With an HP Printer ' eHow.com http://www.ehow.com/how_5817661_print-edge-hp-printer.html#ixzz1JuTJG38a
"Not all HP Printers will do borderless printing. If you don't see the borderless paper option, your printer does not support borderless printing.)"
Apr 18, 2011 | Office Equipment & Supplies
I am trying to print my holiday photos. But my photosmart C5180 printer will not print borderless. There is a white border on the right side on app. 5 mm and 5 mm on the top.
Go to HP Solution Center
Go to printer settings
go to Printer preferrences
go to features tab
choose or check on borderless
Printing on Special media
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=57671&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=1153481
Printing
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=57688&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=1153481
Mac OS X: Printing Borderless 10 x 15 cm (4 x 6 inch) Photos
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846942&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search
Mar 26, 2011 | HP Photosmart C5180 All-In-One InkJet...
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing from iphoto - photos are not 4x6 and not borderless
Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
310 people viewed this question
Seeker5211
Seeker5211
