Question about 5301 LE 2 Way Car Remote Starter System
Viper remote starter malfunction
I installed the viper starter in my girlfriends 2005 Chevy Tahoe, the 2 problems I am experiencing: 1- the vehicle horn sounds off when we use the viper remote 2- the doors all lock within 15 sec of manually shutting the vehicle off with the ignition switch. I am using a bypass module (viper brand) with the bus info and not the wire to wire setup. I also programmed the systems with a bit-writer and apparently I missed something, any help would be appreciated.
4 Suggested Answers
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
SOURCE: Viper Remote Start wont work properly
if it cranks and wont start then its probably the bypass the module thats not working correctly
Posted on Jan 20, 2011
My remote starter will start the car, but the heat will not come on until the key is in.
Did the heater work before? When these units are installed, there are specific relays (optional) that can be installed for various high-current devices such as the HVAC, window defoggers, etc. They require additional parts and labor to install, and may not have been (although it seems unlikely for the heater). Otherwise, there may be a relay malfunction.
Jan 14, 2015 | 5101 LE 1 Way Car Remote Starter System
Cant start car with key
It sounds like you might be having an issue with the transponder or "chip" in that key. When you turn the key and it doesn't start you probably see a flashing key icon on the dash with a circle and a line through it. When you remote start the car it is using a by pass module to trick the car into thinking you have a valid transponder key in the ignition when it starts up. Go to a locksmith and have another key cut and programmed to the car.
Jan 29, 2014 | 5901 Security Remote Start System
I bought a Viper 5701 and I go to use the remote starter, and it turns on and within a few seconds, it turns off. It goes thru the motions of starting again, but it is aggrivating. Any solutions?? I...
I work at best buy. Bring the unit and the reciept back to any best buy and they'll reprogram it for you. The unit is not having a strong enough tach signal.
Sep 30, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle:
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start:
Hope some or all of this helps you!
Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Have a 1995 tahoe disabled by viper security system. howdo i get the power baqck?
define disabled? if you mean it wont start, then turn the ignition on and press the valet switch untill the LED lights solid
Aug 13, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
May 28, 2010 | Remote Start System
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Oct 19, 2009 | Viper 160XVL Viper 160XVL Remote Start...
The vehicle starts , but immediately dies.
I would look at the tach wire it is probly not getting signel back to the remote starter usaly a purple wire on remote starters
Mar 01, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 2001 Chevy
:) Sending you a link for the wire info, as far as the bypass... the 451m is wrong.. I think you need something else, I send you a link to that as well...
Jan 26, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5301 LE 2 Way Car Remote Starter System Logo
112 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
