Question about Acer AL1916B 19" LCD Monitor
MONITOR PROBLEM 6 MONTHS OLD ACER AL1916 (SAMSUNG SHUTTLEX COMPUTER) WORKED PERFECTLY,ONE DAY I TURN IT ON AND GREEN AND PINK LINES ALLOVER THE SCREEN SOMETIMES FLASHING. IF I MOVE A WINDOW IT TURNS SOLID CANNOT SEE THRU. MAYBE RELATED, SOMETIMES MOUSE ARROW ON SCREEN WILL ONLY MOVES SIDE TO SIDE, FREEZES, TURNS OFF, RESTARTS, LETS ME KNOW COMPUTER HAS RECOVERED FROM SERIOUS ERROR. WAITING FOR ACER SUPPORT TO RESPOND. I AM A NOVICE, HELP.
    Genius:
  • 2,985 Answers
This may not be a Monitor problem. So if you can try to get to test monitor on another computer. Check carefully the data cable to ensure there are no bent pins. If it turnout to be a monitor problem then at only 6 months -Acer should replace it. If the monitor works - you should have the graphics card on the computer checked out. If you feel you can do this - and you can- basic checks come back as another request.
Posted on Jun 06, 2007
SOURCE:
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
I was given a 2003 Acer AL1916 monitor and came home and hooked it up to my old Compaq presario computer. The screen is fine but the audio is barely audible. I had speakers hooked to the side of my old...
The speakers are not supposed to plug into the monitor, they will plug into the speaker jack on the back of your computer (usually a green plug or it will have a picture of a speaker next to it)
Hope this helps
Good Luck!
Dec 09, 2008 | Acer AL1916W 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Oct 14, 2008 | Acer AL1917W LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Monitor won't turn on.
it something that is defect in the power mian board. Try to seach any buldging capacitor. that might have problem you.
Nov 23, 2007 | Acer AL1916B 19" LCD Monitor
capacitor has shorted in the main board. Try to look for any buldging capacitor and change it. It will be ok then.
Nov 14, 2007 | Acer AL1916B 19" LCD Monitor
Monitor goes dead AL1914
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
