Question about Craftsman 225 Mph Electric Blower Vac
I am looking for a Defond CPU-Series 13 amp/125 volt microswitch
Where can I buy a Defond CPU-2113 safety switch for a Toro Blower/Vacuum?
If you do not use the Blower / Vac for Vac you can cut out the the reset switch, it's only when you get foreign material in the impeller using the Vac stopping the motor, I cut out the switch. As you look at the Defond switch (side with writing you see a white wire and a black wire side by side. mark the black wire with a small piece of tape 1-1/2 inches from the connecting lug. Cut all wires off the switch. Strip wires back 3/8 to 1/2 inches. Use heat shrink tubing
and slide it back on the black wire with the tape, same thing thing with the black wires on opposite side of the switch. Use a end to end splice as opposed to a parallel splice because of wire routing space..Splice the white wire with the black with tape, Then the other two black wires. using heat shrink tubing to cover the splice. Good idea to take a picture (smart phone) so as to see wire routing after you separate blower halves, very little wire routing space. Make sure motor is seated in it's nest before joining halves together do not use Vac if you use this fix. Mine works just fine, save $60+ bucks.
Nov 01, 2014 | Toro Garden
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
Looking for a source to purchase Defond CPU-2113 replacement switch for Toro Blower Model 51599. I live in Omaha, Nebraska.
I can offer it. drop me a memo send the Defond drawing and the quanitity to: roman dot xiao at gmail dot com
Jan 07, 2011 | Garden
Sensor says it's full; it's not full and won't operate
Check for a sticking float arm. The float arm activates a microswitch when the tank is full. Also look for a sticking Microswitch. Here is a picture of the float arm.......follow the arm to the location of the microswitch. If neither are stuck, look for a loose wire in series with the microswitch. Hope you find this to be very helpful moving forward. :-)
May 19, 2010 | Fedders A7DH45B2A Dehumidifier
Ho wdo i find power to install a 12 volt light to
YZ series mx'rs dont have a lighting coil thus do not have a 12v supply.WR series do.(but they don't come in 125cc at least not here in Oz). Am not sure if WR 250 stator will fit(I very much doubt it).The best next suggestion is to check in MX magazines in advertising section uasually at rear of mag for stator repairers & ask them for advice.
Nov 23, 2009 | 2003 Yamaha YZ 125
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Pioneer rear projection tv
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
May 07, 2008 | Pioneer SD-P62A3-K 62" Rear Projection...
Salton expresso cappaccino maker microswitch
The Honeywell V7-1C17E9 microswitch is a form/fit replacement for this Defond switch. You can get it at www.alliedelec.com. I had one fail in a Delta DT1600E Pressure Washer. The replacement switch worked great. Good luck.
Oct 26, 2007 | Coffee Makers & Espresso Machines
Craftsman 225 Mph Electric Blower Vac Logo
41 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
