Question about Copystar CS-1530 Copier
I have a cs-1530 and when using the auto-feed the copies made come out with a black line down the middle.
    President:
  • Copystar Master
  • 990 Answers
Dear Sir; Open the cover on the left hand side have a piece narrow strip glass (or white reference on the cover) use rubbing alcohol to clean it.
Posted on Jan 10, 2009
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
When printing or copying I lose almost an inch on the top margin
If you are using the auto feed, you need to reset your printer. Your manual will have instructions. This happens to mine ocassionally after I have to replace ink.
Jun 25, 2012 | Kyocera Copystar CS-1820 Black and White...
Black line running down the middle of the page when faxing or copying using automatic feed tray. If I lift lid and copy no line. Receiving fax not line?
Generally this problem is due to the the glass under the lid being dirty. Some combo units have 2 scanning areas, the large one you are using to copy ans a small one it runs the faxes through. I suggest you clean any and all glass you can find on the machine and give it another go.
May 04, 2011 | Brother Office Equipment & Supplies
Black line through my copies
It's most likely a drum. If you open the door on the left side (both drop down) you can see about 1/2 way up a shiny black "roller" or cylindar. If it has the strip on it as well, thats your drum unit and it will need to be replaced. If not, than it may be either the fuser roller (which typically doesn't just "happen" , it takes a while to wear a 1" strip off of that roller) or it may be optical... which also doesn't just happen! The drum can be replaced by end user if you are carefull!!!!
Apr 08, 2009 | Copystar CS-2050 All-In-One Printer
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Black line in auto feed
If you lift the scanner cover, you should see an area on the right end of the platen glass marked at the edge with arrows as Read Area. This is the area used when documents are scanned through the auto feed. Make sure that the glass is completely clean in this area, as any dirt will show up as a line on the copied image.
Apr 18, 2008 | Canon imageCLASS D880 All-In-One Laser...
Copystar CS-1530 Copier Logo
109 people viewed this question
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
polytek
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
