Sony Cybershot DSC-H3 Digital Camera Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not realizing full zoom capabilities on my camera
It should be 10 times zoom as normal, but seems to be only utilizing part of the zoom
  • joe1717 Jan 10, 2009
    I had the lens set funny, as if there was a different lens attached.
    Fixed it! Thanks anyway.
  • Anonymous May 11, 2010
    Check zoom option in camera Menu and set it accordingly.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jan 10, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957338
Points
33084
Nikon collpix l810 lens shake automatically
The Nikon Coolpix L810 is a great camera capable of taking very good and sharp pictures, even in bad light conditions. It has a Vibration reduction, that makes it even possible to shoot pictures without tripod when you zoom in very far. If normally with the same lens length you should need 1/200 of a second your camera should still be capable of taking that picture with only the same blur from shake, with 1/50 of a second. But if you ever should use a tripod. make sure you switch off that feature. Because the Vibration reduction, works with a staking lens element. that should compensate the movement of the camera, by shaking in the correct direction opposite to the movement of the camera. The element will still shake and so blur a picture, when the camera is placed on a tripod.
Don't try to shoot pictures with the zoom on full extension, in bad light conditions. That also won't work. Lots of things can be done with the camera, but to everything is a limit. Most of the time that limit comes sooner when there is less light.
Hello! I actually have a TZ3 and have been having problems with the quality of the pictures without using the zoom (grainy) as well as problems with the quality of the picture when using the zoom...
Hello, yes a few suggestions "grainy" could be from an auto ISO setting the sensor speed high as in possibly ISO 400 even 800 or higher you get the pictures but it's grainy. On pocket point and shooters this is most often the case in full automatic modes and on your camera it's called "Intelligent ISO Mode" You should consult your manual and select a more user selectable ISO speed manually. Another feature with your camera is image stabilization this you can turn on or off preferably off when the camera is mounted to a tripod. Okay for the blurry part on the zoom the quickest way to explain this is every tiny movement you make holding the camera is magnified 10 times, this is where the image stabilizing feature would be handy. Jennifer in my younger days I could hold a 35mm camera with a 300mm lens steady at 1/60 of a second now I use only a 200mm lens with image stabilization "on" to get the same results. What you have is a full time auto everything camera if it's working for you it doesn't matter if it's 3.5 years old. You are still working with a 7.2meg camera with a print capability of 11x14. hope this answered some of your questions.
I have a digital camera powersot SX 200 lswith 10
Here is the address of the Canon service Center (Ahmedabad):
101, SHIVALIK-10, OPP. SBI ZONAL OFFICE, NR. GRAND MALL, S.M. ROAD, AMBAWADI,
AHMEDABAD
GUJARAT
Tel : 26306293, 26306294, 26306295
Fax : 98242 63285
Thanks for using FixYa
4helpful
2answers
Faulty zoom
try to reset factory setting
2answers
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Quantaray 28-200mm Aspherical IF
If I read this right, your lens is a 28 to 200mm zoom lens with aperture of f:3.5 - f:5.6. What this means is that at 28mm it has a maximum aperture of f:3.5. When you zoom out to 200mm, the maximum aperture is now f:5.6. This is perfectly normal for a zoom lens of this type.
Typical situation in Shutter preferred mode. I have the shutter set at 1/125 of a second and the f:stop is f:3.5. When I zoom out to 200mm, the shutter speed is still 1/125 of a second, but the f:stop is now f:5.6 and I have decreased exposure (darkened the picture) by almost 2 full f: stops.
Realizing this, I think that "turning off the camera" really isn't a fix. The problem is realizing that the aperture will change as the focal length of the lens changes (as you ZOOM in or out on your subject). Try the aperture preferred mode and you should note that the shutter speed will change as you zoom in and out.
Most important, pay attention to shutter and f:stop info in your viewfinder. FYI : Zoom lenses that hold aperture at all ranges cost several thousand dollars, and canon makes them - they weigh a ton.
Panasonic AG - 196
well danny,
that cam is an analog. well, as long as there are full size VHS VCR's there is going to be full sized VHS camcorders as well. The convenience of dealing with only one tape format is undeniable. Not having to convert the tape out of the camcorder and into your VCR, without wires or adaptors or losing quality can seem more important to some people, than the overall size of the unit. By utilizing the optional professional wide-angle lens you can cover all the bases. This unit is straightforward and easy to operate and the results are top notch too! A full-size VHS camcorder, the AG-196U is ideal for those just getting started in video, as well as for educational and institutional applications. It offers a 14: 1 two-speed power zoom lens, low-light capability, Audio/Video fade, has advanced recording and playback functions as well as digital effects to meet almost any application. Extremely sensitive 1/3" CCD with 420, 000 pixels provides outstanding picture quality, even under low-light conditions.
you'd feel like a professional with this cam.
cheers
Won't focus when zooming into the subject
It seems that the lense element which mooves while zooming the camera is stucked. normally this happens when the camera suffers a heavy jery, may be by dropping the camera. Resulting into disalingment of the lense assambly. You will need the help of repair shop to solve the problem.
H1 SmartZoom capabilities
tried the smartzoom myself for the first time today .. I'm pleasantly suprised .. no teleconverter yet .. :-)
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
