Resources required to print
When ever i try to print an exel file it gives me an error resources required to print.
2 Suggested Answers
BlacMamba
  • 215 Answers
SOURCE: we are trying to print a document that was created
Try saving the document in excel 2007(.docx).....open it and try printing again.
Posted on Nov 11, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Kyocera printer says printer not activated error code 30?
    Section I: Damaged Customized Form
    • Try to e-mail/print using a standard form or a Standard Report such as the Balance Sheet
    • If the error occurs as soon as Print or Email is clicked, skip to the next section
    • If able to select the standard form, and the form prints or emails successfully, See Article ID 11456 (Error: "Bad or missing form file") in Related Resources
    for more help visit https://cbrtechsolutions.net
    Oct 26, 2012 | Kyocera Office Equipment & Supplies
    Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
    Send the font information for each page in the PDF file when you print.
    For Adobe Acrobat Professional 9:
    1. Choose File > Print.
    2. Click on Advanced.
    3. Choose Postcript Options.
    4. Under Font and Resource Policy, select Send for Each Page.
    In Adobe Reader 9: try this 1
    3. Under Font and Resource Policy, select Send for Each Page.
    may or may not work try it
    Hopefully this will be helpful to you all
    Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
    Autocad 2010 problem
    If you run Win7 in XP mode, all should be fine.
    May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
    Exel 2007 not open in exel 2003
    This is because 2007 excel uses a different type of file. You may follow the directions at the link below on how to save files in 2007 excel so that you can open it in 2003
    http://office.microsoft.com/en-us/excel/HA100141071033.aspx
    Sep 25, 2008 | Microsoft Office Professional 2007 Full...
    EXEL 2007
    If there is anything else please do message me.
    Downloaded new version of avg 8 giving me this error file avgwdsvc.exe error 0x00736b1
    I have found that the AVG 8 is not real compatible to vista. Suggest the sheild deluxe for antivirus, exellent for XP and vista.
    May 31, 2008 | Computers & Internet
    How to linc between two exel file
    If you have both files open at the same time, you can use drag and drop in formulas between the two files. You can also go to the menu item "Link" and activate/update links from there. Thanks for rating FixYa!
    Apr 16, 2008 | Computers & Internet
    382 people viewed this question
    k24674
    jasbo
    jasbo
