Question about Acer AL718 17" Flat Panel LCD Monitor
Power issue I have an acer al718 17" falt screen LCD , i recently moved, when i connected the computer back up the monitor powered up for between 5 and 10 seconds then switches off and on , even diconnecting from pc doesnt help , also if you push the off button on the monitor you can still hear the speakers ticking as if it is still turning off and on . i have tried different power leads and also changed wall sockets and power boards . Anyhelp will be very welcome
  • Anonymous Dec 16, 2008
    I have the exact same issue. Monitor doesn't turn on and I keep hearing those speaker 'pops'.
  • Anonymous Apr 26, 2009
    wont' turn on
    President:
  • Acer Master
  • 1,314 Answers
See if your video card inside your PC hasn't come loose. Take it out and push it back in again to reseat the card. Then, once it's firmly secured, try the monitor.
Posted on Jun 10, 2007
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Acer AL1912 19" LCD Monitor goes black after power up
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Two monitors blank, but on
<table x:str="" style="border-collapse: collapse; width: 124pt;" border="0" cellpadding="0" cellspacing="0" width="165"><col style="width: 124pt;" width="165"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 124pt;" height="19" width="165">http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php</td> </tr></table><br />I wish you problem can be solution. <table x:str="" style="border-collapse: collapse; width: 54pt;" border="0" cellpadding="0" cellspacing="0" width="72"><col style="width: 54pt;" width="72"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 54pt;" height="19" width="72">&lt;a href="http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php"&gt;10.4 inch LCD Monitor&lt;/a&gt;</td> </tr></table>
Mar 24, 2009 | Acer AL2216WBD LCD Monitor
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Shadowing on ACER AL1711 17" LCD Monitor
Did you ever find the problem with this unit? BTW, a crappy video cable can cause this or the input impedance has changed on the monitor due to improper connections.
Oct 28, 2007 | Acer AL1711 17" LCD Monitor
Flickers and shows acer logo
Perform a system recovery:
2 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Alt/F10 during boot right after Acer splash screeen on startup
http://us.acer.com/public/page11.do?sp=page74&UserCtxParam=0&GroupCtxParam=0&dctx1=25&CountryISOCtxParam=US&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+States&crc=790373818
Oct 26, 2007 | Acer AL1716 17" LCD Monitor
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Acer AL718 17" Flat Panel LCD Monitor Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
