Question about RCA P46924 46" Rear Projection Television
Rca 46 proj
I have replaced the convergence board and need to set the convergence on my rca, i am starting from scratch and need to do a compleat re alighnment and adjustment, eg. drive bias focus and convergence please help if you can.
  • RCA Master
  • 3,459 Answers
Projection TVrca 46 proj - 2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise
calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 30, 2010
  • blfrancis Feb 07, 2011
    My set also seems to have this convergence problem but in the menu there are no settings for convergence adjustment; just basic picture controls. Does this mean the only way to solve the problem is to replace the diodes? BF
Have a yellow and blue hazw from left to righton the people and lettering rca 56 inch tv
Hi: this is dur to convergence board failure, there a three micro fuses on the deflection board power suppply that need checking, also while checking these fuses check the solder connections around your flyback transformer as this is the most common reason these fuses fail. If all fuses are good then a replacement of the convergence Board is necessary at this point.
Aug 18, 2010 | RCA P46810LV 46" Rear Projection...
R C A 52" Rear Proj. TV
https://www.manualsparadise.com/MainSearch.do?brand=429&model=MM-52100&elementChanged=Find
You can find the service manual to answer all your questions usually for around 25$
If you need any other assistance please let me know.
Thanks,
Lee
Sep 12, 2008 | RCA Televison & Video
Hit by litning
my friend it is the tv tunner that needs to be replace you will have to take your set to a repair shop for repairs.tv needs qualified tech to repair them.you might cause injury to your self.although you want to save money it is best to have a tech deal with your tv,than doing more damage to your tv and to yourself.it will cost you less on the longer run.good luck
Jun 19, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Rca p46813bl convergence problem bowed in the
OK., I know this set very well. It almost never has a convergence problem.
With the set unplugged, remove the back cover--there is a small circuit board mounted ABOVE the main boards--it is about 10 inches wide and 4 inches tall---On the far right side of it are several DIODES---two are much larger then the rest--what usually happens is one of the large diodes is shorted--5 dollar part---the board only has a few plugs and 4 screws that hold it in---easy to remove--check all the diodes(the two large ones first)
If either of the large diodes read like a fuse you FOUND YOUR TROUBLE.
LET me know if you need ANY help or Advice--I am here to help people---I have seen several sets identical to yours with the problem you describe.
Regards, SD TECH
Oct 06, 2009 | RCA P46924 46" Rear Projection Television
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Need service code for rca proj tv mod d52w2o
thank you for your follow-up on my request. i simply needed the service code access for the set i named. i found it elsewhere- just hold down vol. down-channel down for 8 seconds until set powers up. i needed to access the dynamic digital convergence-had to perform complete convergence. lightining strike had apparently erased settings.
Jun 25, 2008 | Televison & Video
Phillips Proj TV 9P5034c101
call tech..converge eprom has to be changed from old to new board.
Nov 16, 2007 | Sony KP-53V75 53" Rear Projection...
Convergence Pattern
Hi, Your problem is in the convergance? Ever done the convergance on a proj tv? If you have, then you can find the convergance board behind the speakers as i recall IF YOU HAVEN'T DON'T START NOW. UNLESS,,, you have the service manual, or the knowledge to, and the test patterns neccassary, to do it. Each color has approx 10 adjustments for vertical deflection, and 10 for Horiz. IF YOU TRY IT and don't have any idea,, you WILL make it worse!!! It takes about 4 hrs to do it right for a qualified tech so ya better think of it as an all day affair! good luck
Feb 24, 2006 | GE 46GW947 46" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
