Question about TruTech PLV1615T 15 in. LCD Television
Black bars show up when not in HD
I have a 32" FLAT SCREEN TELEVISION, (i COULDN'T FIND THE EXACT TELEVISION LISTED) AND WHEN NOT IN HD BLACK BARS WILL APPEAR ON EACH SIDE OF THE SCREEN. I THINK I CHANGED THE SETTING SOMEHOW BUT CANNOT GET IT TO GO BACK TO NOT HAVING THE BLACK BARS. CAN YOU HELP ME WITH THIS PROBLEM?
  • 944 Answers
Please let us know which exact television you do have, and then we can hopefuly find a solution :)
Posted on Aug 15, 2007
  • 934 Answers
Sounds like you've changed the aspect ratio to a 4:3 and you need to put it back to a 16:9. Go into your menu and find the sub menu that allows you to change "format" or "aspect ratio". Adjust that until you have it at 16:9 and see if that corrects your problem. Good Luck Bill
Posted on Jun 08, 2007
3" black bars top and bottom of screen. Can't
either you have the video setting of the television set to wide screen or you are purchasing "WIDE SCREEN" format dvds instead of "FULL SCREEN" format dvds
Oct 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
32' Samsung LCD Tv vertical bars on screen / sound
hi,
your lcd panel micron tube has already wron out. time to replace the panel
Apr 25, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Picture ratio
Programs that are recorded in 16:9 format appear full screen on a 16:9 TV. A program recorded in a standard 4:3 format will either be stretched to fit the screen or have side bars to fill the screen area. In the case of HD channels, the black side bars are part of the picture which is being broadcasted.
Apr 22, 2010 | LG 32LG30 32 in. LCD HDTV
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony wall mounted 740hd pops from hd to non-hd
it has to do with the brodcast testing digital frequenies. they will probably solve them selves when the change happens.
Jun 03, 2009 | Sony Bravia KDL-32N4000 32 in. HDTV LCD TV
Screen shows black at top and bottom from flip video hd
I think you can use doremisoft flip converter that can crop your black bars and other addition editing functions, such as cut clips, join videos, add special effect and so on.
YOU can free download at:
http://www.flip-converter.com/article-flip-mac/flip-video-to-avi-converter-mac/
have a try.
May 25, 2009 | Pure Digital Flip Video Ultra Camcorder
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
May 06, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Pic.not fitting on screen
the black bars on the sides are normal there are settings in the menu to change the screen sizes.
Dec 01, 2008 | Philips Magnavox 42MF521D/37 Television
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
