Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a vison pro th8320u cant get aux heat to work
Vison pro th8320u
  • 700 Answers
Http://customer.honeywell.com/techlit/pdf/69-0000s/69-1871.pdf take and click on this link, then go to the installers menu and on option 0170 that is where you have to program the thermoistat to have aux heat. good luck
Posted on Jan 25, 2009
What does it mean when it comes on AUX heat?
The system type has been incorrectly set during the installer setup. The t/stat thinks there is auxiliary heat equipment that is controlled by a signal on the Aux-E terminal which you obviously don't have. My recommendation would be to go to the Honeywell website and download a copy of the installation guide for the FocusPro 8000 and go through the installer setup again but select the appropriate system type under setup function 1.
Feb 13, 2016 | Honeywell Vision Pro 8000 Touchscreen...
Need instructions for remote AUX ykr-f/06
anyone have a manual book for a remote control aux ykr-f/06 cant set the timer could anyone scan and send a copy to bug-it@hotmail.com plez
Jan 23, 2013 | Heating & Cooling
Suspect programing error on Honeywell TH8320U in Aux cycle
Not making any sense. I don't think you have any programming error because as you said the blower DOES kick on, then begins to shut down before ramping up again. I would have to guess it is internal of the AHU. With that being said, you jump the aux heat and it works fine. I would check high and low voltage at the motor and be sure you are not losing anything when in normal operation. Then, possibly determine a bad motor????? Good Luck, got me puzzled too!!!
Jul 13, 2017 | Heating & Cooling
I have a new bryant 2.5 ton 410 puron heat pump and it shut off when the temp get cooler. The temp right now is around 36. Is there anyway to get it to shutoff at a lower temp. so the aux heat won't kick...
Heat pumps only work down to a certain temperature, 35-40 degrees outside temp. Once it gets that cold the system cant pull any heat from the outside air and the aux heat kicks in to make up the differance.
Nov 23, 2010 | Heating & Cooling
Playing MP3 Via AUX comes out crackly
Try turning the volume lowwer on the mp3 player and higher on the head unit. The radio is trying to amplify an amplified sound which is why you are getting distortion.
Mar 22, 2010 | Car Audio & Video
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Jul 27, 2009 | Heating & Cooling
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
I'm trying to hook up a honeywell touchscreen thermostat and need to know what wires go where.
i have a vison pro th8320u and i cant get aux heat to operate also aux heat on will not come up on the touch screen.
Jan 04, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
121 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
