Question about Exercise & Fitness
Grinding and metal shavings from eclipse 1100 hr elliptical trainer
How do I fix my elliptical trainer so it stops grinding metal inside the spinning wheel
  • 28 Answers
SOURCE: What is an elliptical trainer?
An elliptical trainer or cross-trainer is a stationaryexercise machine used to simulate stair climbing, walking, or running withoutcausing excessive pressure to the knees.
Posted on Jul 09, 2012
SOURCE: How many calories can I burn on an elliptical trainer machine?
how many calories you burn depends
a) on your weight
b) on the exercise speed
c) on the exercise level
d) as a combination of all factors on your heart rate
For example, I at 80kg usually do about 400 cal in 27 minutes @138 heartrate :-)
Posted on Jul 23, 2012
doreen_w761
  • 88 Answers
SOURCE: Is it better to get a rear-drive or front-drive elliptical trainer?
To best answer this question for you I have found an excerpt about this topic written by a fitness professional. Read it over and then consider your options.
"The rear-drive elliptical trainers have a more intuitive design," explained the fitness equipment expert. "When you exercise, inherent in this design is the proper biomechanical motion. It's a more natural motion. Most commercial units are the rear-drive type, because it has a floating system with free-rolling bearings. This means there are less mechanics, and less mechanics means less wear and tear. Also, mechanics in the back allow the user to sit forward, maintain the proper posture and, thus, get a better workout."
Our expert went on to describe front-drive ellipticals: "With front-drive elliptical trainers, they have to add extra linkage to make the pedals more comfortable. They also have to use a track, which can break down due to dirt build-up. There are more mechanical components, which need constant maintenance. More mechanics lead to more wear and tear and more noise. These machines tend to lose their smooth feel. The mechanics pushes the user back, making it necessary to lean forward, so the workout is not as effective as you get on a rear-drive model."
Posted on Aug 02, 2012
  • 28 Answers
SOURCE: How do I clean my elliptical trainer?
You will notice that dirt accumulates on both the wheels and track. First, I suggest reading you user manual. To avoid dirt build-ups, I recommend wiping the machine after each use. This is not instead of a cleaning, but will limit the time you spend cleaning the machine. If your manual is not helpful, I found a great article called "Keeping Your Elliptical Machine Clean" - this should help.
http://www.abcarticledirectory.com/Article/-Keeping-Your-Elliptical-Machine-Clean-/896160
  • 28 Answers
SOURCE: My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
When I program my Eclipse 1100 hr/a for any amount of time, it shuts off after 5 minutes.
The timing circuit has become unstable and the circuit board may be defective. Selection rates cannot be set and thus only a replacement controller will fix the situation.
Feb 26, 2014 | Fitness Quest Eclipse 1100 Hr/A Elliptical
When running get error message your pressing on the board too hard?
RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
God bless you
Nov 13, 2013 | Life Fitness Lifefitness 9100 Hr Treadmill...
I purchased a used Eclipse 1100 Hr/A elliptical machine and discovered that one of the swing arms is in the wrong position, allowing the food pad to rub against the machine's base support as it cycles...
I remember having this problem before. Are you sure that you can't find a manual online? Sears online parts may offer a pdf. The arms face inward in the brackets--not outward. Switching (main) arms appears to be logical....
Aug 06, 2013 | Fitness Quest Eclipse 1100 Hr/A Elliptical
My eclipse 1100 hour monitor is not working (already replaced batteries and still nothing)
Check it out. If you machine monitor shows and e-1 when trying to turn on. Take out the batteries and unscrew the four screws on the bottom of the monitor unplug it from the elliptical. Put the batteries back in turn on monitor the plug it back to the elliptical while still on and screw back in places. It worked for me hope it works for you too.
Brian Pickens
Long beach ca
Oct 15, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Exercise & Fitness Logo
66 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
