Question about Sharp R-1500 Microwave Oven
Start Button won't turn of micro wave cooking function.
Start button won't turn on cooking feature. Eveything esle works fine.
  • Anonymous Jan 11, 2009
    Everything works on my microwave but the cooking function.
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad bottom door switch or its mount is loose.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 11, 2009
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 11, 2010 | Maytag MMV4205 Microwave Oven
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Sharp R-1500 Microwave Oven Logo
126 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
