Samsung 50in plasma FPT5094W says CHECK FAN Where is fan that needs to be replaced?
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
There are three fans inside. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
SOURCE: had loud pop and then no picture on the vizio 50in. plasma
TV was on with no picture problem. Left the room and when I returned the picture was very dim. Turned system off and turned back on. Picture didn't change, but heard a loud pop from the back of the TV.
Posted on Jun 22, 2008
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
caroldon
  • 17129 Answers
SOURCE: samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
Posted on Jul 22, 2010
eagle338
  • 4889 Answers
SOURCE: Samsung PN50A450 plasma 50in no sound...
Have you checked if you have manually turned off the speakers? Menu->Audio?Sound -> Speakers. Select it and make sure its set to on. If it is then connect a pair of headphnes into to the headphones jack and see if you have sound(that will help us verify if its malfunctioning speakers)
Posted on Jan 25, 2011
joan8286
SOURCE: is there any solution for "check fan 1" Samsung LN40A650A LCD TV
Just fixed my Samsung LN40 check fan #1.Unplug, Take the back off (like 20 screws were hard to find them all) fan is exposed in the middle. Unscrew fan, used q-tips and nozzle tool on vacuum cleaner to remove built up dust gunk. Blew in center of fan to dislodge dust. Screwed fan back on, plugged in to see if fan was spinning to cool TV. It was and the check fan message disappeared. Put the back on. Feeling Lucky no big repair.
Posted on Jul 12, 2012
Could the Tcon board in a 50in samsung plasma tv cause a white screen?
Plasma TVs have no T'Con board. Only LCD TVs have. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 26, 2016 | Samsung PN50B450B1DXZA - 50in Ws Plasma Tv...
Replacing glass screen on 50in plasma samsung
if your plasma tv is not gurantee and company is not going to repalace it the price of a plasma panel more or less is about 70 %
of a new plasma tv this means that if a plasma tv is 1000 usd you have to pay at least 700 usd
Oct 15, 2014 | Samsung PN42A450 Plasma TV
Samsung le40a766r no.1 fan fault. I removed the back of the tv and the fan was stuck so i cleaned it and it was functioning. so i replaced the back and the tv worked fine for about 30 mins. then the fault...
Replace the fan. Check the fan speed regulator circuit too. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
If the fan has gone to its efficiency, this kind of fault can occur.
Mar 17, 2014 | Samsung HP-P3761 37 in. HD-Ready Plasma...
HP-R4252 Samsung 42" Plasma cooling fan won't work. Replaced the fan, and new one won't work either. Service center said $250 to repair fan. What else could it be, and can the tv be run without fan if an...
Hi, does your replacement fan is the same exact part number as the original?. If your replacement fan is like the ones used un pcs with the third yellow wire, then this wont work.
Sep 12, 2013 | Samsung Televison & Video
I have a Samsung plasma tv model fp-t5894w when i turn it on it will say check fan then turn off
By Check Fan it means that the fan inside your plasma tv is not working. If the fan will not rotate the main system control will detect it show the message that fan is not working to avoid further problems. Its a fan with three wire. Two wire for power and the third on for read the status of the fan.
Just oppen the tv. Locate the fan normally you can find it on the top side. There will be one or two fans in plasma tv.
Remove the fan if its available anywhere near then replace the same with a new one. If its not avilable. The do the following.
You can see there is a spesification sticker on the fan. if you remove the sticker then you can see its bearing. Put 2 drops of any lubricating oil. Roate the fan leaf with finger for some time. Replace the sticker and fix the fan back.
I have added a video which will help you to do the same.
Then power On the tv and check is the fan failure displays again or not. If its displays the same the you should by an new fan.
Ajin
Apr 03, 2012 | Samsung Televison & Video
Hi I have a Samsung HP-R4252 42" Plasma HDTV. The
Try website like Ebay.com to buy a refurbish tv main Tuner signal board.The part number it is on a sticker on the board,must take the tv aparts to read it.The fan itself buy it on Ebay.com too,or try website like Partstore.com to buy a part fan.
Jun 09, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
My television says check fan no. 1 and it shuts off by itself. whats the problem?
It means the Fan is either Defective or has Dirt and dust built up on Fan and Fan needs to be Cleaned.
Dec 31, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Message on my tv reads check fan 1..
check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Jan 30, 2010 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
