SOURCE: how to reset an acer
you have to change your theme if the visualization have change..
on desktop right click>properties?change to your OS default THEME
SOURCE: increase volume of acer aspire
Press and hold the Fn key and the Up Arrow to increase volume. (The Fn key is located in the lower left corner of the laptop).
Press and hold the Fn key and the Down Arrow to decrease volume.
Press and hold the Fn key and F8 to mute/unmute the speakers.
The information for this is found on Page 6 of the manual.
Follow this link for the Acer Aspire 4741z manual: http://global-download.acer.com/GDFiles/Document/QuickStartGuide/QuickStartGuide_Acer_1.0_A_A.zip?acerid=634121049878053335&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%204741Z&OS=ALL&LC=en&BC=ACER&SC=PA_7
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
SOURCE: How can I on the bluetooth on my laptop aspire
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works.
I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
SOURCE: i bought a brand new
Just download Windows Password Key from http://download.cnet.com/Windows-Password-Key/3000-2092_4-75031111.html?tag=mncol;6
and burn it on a disk and then boot your computer from this cd, it will clear the password of your account without knowing the current password.
SOURCE: how do increase the volume
I hope I can help!
If you want to use the buttons on your keyboard to adjust your volume, just hold the "Fn" button just to the left of the windows key, and then push the "up" arrow or "down" arrow. To be clear, those are just the main arrow keys, up will turn the volume up, and down will turn it down (of course).
I hope that helps!
