Question about HP Compaq Evo n610c Notebook
Power connection on back of laptop is loose, wont power up. Is this connector part of the motherboard or is it a separate piece ?
  • 34 Answers
Hi!
the power plug is on the main board
strip the laptop and re-solder the power plug quick and easy
regards craig
Posted on Feb 15, 2009
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 28, 2010 | Acer Computers & Internet
Connector not allowing charger to charge battery, loose in back of lap top
This will require either the replacement of the power connection by a competent board repair service or replacement of the motherboard
Example: (Not necessarily a recommendation)
http://comprehensivecomputing.net/79_dollar_power_jack_repair.htm
Motherboard
http://shop.ebay.com/i.html?_nkw=Inspiron+6000+motherboard&_sacat=0&_odkw=Inspiron+6000+power+jack&_osacat=0&_trksid=p3286.c0.m270.l1313
Sep 27, 2010 | Dell Inspiron 6000 Notebook
My acer aspire 1360 wont turn on when i power up al;l i get is a black screen, the motherboard light flashes once and then goes off leaving only the power light on please help!!
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 22, 2010 | Acer Aspire 1360 Notebook
Laptop wont power up but the light is on where the power cord plugs into the laptop
etc....
Sep 22, 2010 | HP Pavilion dv5-1138nr Notebook
Dell inspiron 1545 wont turn on power light comes on but no screen display
etc....
Sep 21, 2010 | Dell Inspiron 1545 Notebook
My hp pavilion dv6500 won't boot up. When the power button is depressed, the power light, dvd light, and all other lights near the keyboard come on for a split second, then shut back off The screen never...
etc....
Sep 19, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Dec 22, 2009 | Sony VAIO FW Series VGNFW275JH
I have a Gateway W340UI. powercord connection
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely. A computer repair shop can do the repair, I suggest you get a quote first.
Sep 03, 2009 | Gateway Computers & Internet
Samsung laptop black screen
Sounds like a loose connection between your mainboard, inverter or LCD. Try to connect an external monitor and see if the display appears to the external monitor. If a display appears on the external monitor, you need a qualified technician to check your laptop. I fixed 3 laptops with that same symptoms, 1 has loose connector, 1 has ground problem and the other is an inverter.
Apr 09, 2009 | Intel Motherboard
Wont turn on
This is a result of a broken power supply connector. Where you plug your power adapter cable into the laptop is a small soldered block connector inside. Over time, if not careful, this can become loose and disconnected from the motherboard, causing a loose connection. The smell you experienced was from the partial contact from the power connector to the motherboard. It arced and most likely shorted the contacts, as they separated. Now, your power supply connection to the laptop is not working anymore, and thus, you have no charge or power to your laptop. It gets worse, unfortunately. You need to find an experienced person that knows how to solder contacts on circuit boards to repair it, or bring it to a place that does component repairs on computers. The charge will be from $150-$175 usually for this service, but will fix your problem I am confident. Sorry for the bad news...atleast you know what to do to fix your problem.
Mar 23, 2009 | Computers & Internet
HP Compaq Evo n610c Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
