Question about Sony KV-9PT50 Television
Sony KV-1946R TO WHOM IT MAY CONCERN, PLEASE HELP ME OUT WITH THIS PROBLEM, MY PUSH BUTTON OF MY SONY IS NOT WORKING GOOD, AS WHEN I TURN ON THE TV, SOME TIMES IT SWITCH OFF BY HER SELF IN 5 SEC, OTHER TIMES IN 2 MINTUTES ETC, WHAT SHOULD I DO, OR WHCIH SWICH I HAVE TO SHANGE. HOPE TE HEAR FROM YOU I REMAIN HAROLD COLOMBIA , BOGOTA
    Problem Solver:
  • 8 Answers
If your television is an older model probably the switch is defective.need to be replace,if its a newer model then the trouble must be in the power supply section.contact a tv technician tto check the trouble.
Posted on Nov 30, 2009
Remote will not work
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
What are the codes to program the jensen remote to a sony tv?
to manually let the remote find the code as i couldnt find the actual sony code since you didnt list your tv try this proceducure
Turn on your tv manually.
Hold on to the (tv) button and on/off button for the same time for 3 secs.
On/off button will light up.
Push on/off button until the tv turns off. up to 30 or so times
Then push the stop button on the bottom of the remote tosave the config.
please let me know if that works
Mar 17, 2011 | Jensen 143307 Remote Control
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My sony trinitrion always displays the video input. Who used to faed away, but is now staying on all the time. Doesn't matter if it's input 1, 2, 3, 4, etc. Turned off and unplugged but still displays all...
Using the TV's remote and having the TV on,
hold down the "reset" button and manually turn off the TV directly from the unit.(not the remote)
Release the "reset" button.
Turn the TV back on-directly from the unit.(not the remote)
A dialog box will appear on your screen.
Choose "Auto" by pushing the + on Channel Selection button on the unit (not the remote).
Use the TV/DVD selection to return to your cable input.
Jul 17, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron 30XBR910 Not Turning On
The three blinks code(sony error codes) indicates a problem in the power supply. In your case since you manage to turn it on after a while it may mean that you have weak capacitors or bad solder joints in the power supply.
Hope this help Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 01, 2009 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Sep 28, 2009 | Sony Televison & Video
URC-22B doesn't work with my BEKO tv.
Check with this method. Manually turn on your tv.
Then push and hold the code saerch button until the light stays lighted release the button.
Push and release the device button you want to set TV.
Now you got to push and release the ON/OFF button until your device turn off when your device turn off stop and push and release the enter button for storage the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Jun 12, 2009 | Televison & Video
Sony Trinitron TV 32"
http://www.weltonusa.com/MiscManuals/KV32FS120.pdf
The above is where I found the manual. Using the timer is on page 39. Push the menu button and highlight current time set up. Select it and set the time with the up and down arrows. Tehn push menu to save the correct time. Then go back and turn thr timers off. I hope this helps.
Sep 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV will not turn on
Yeppers ,This is how they go out. All of a suddenly and sometimes while your watching it. Right in the middle of a good movie too!!. Your problem could be anything from the horizontal drive circuit or power supply problem If your not experienced with solid state repair then you should get a tech to assist you with this repair as there are no user serviceable parts inside this set and could be very dangerous if you dont know the safty issues concerning the HI VOILTAGE. Good Luck
Jun 26, 2006 | Sony KV-27S42 27" TV
Sony KV-9PT50 Television Logo
206 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
