Question about Gateway MD7818u Notebook
My laptop shut off and I can not power it back on even after a power reset. What can I do?
    Problem Solver:
  • 6 Answers
Try taking out the battery for afew second and replacing it. Or take the battery out and just use the charger to power it on.
Posted on Nov 29, 2012
Hi, I have a 1.5kva cyberpower inverter installed but it doesn't charge the batteries even after displaying the input voltage on screen. It will just drain the batteries and then shut down the output.
Unless a battery is completely drained, over time it begins charging less and less. If your laptop seems to run for less and less time each time you unplug it from the wall, you probably need to reset it. This is a simple process.
Disable all power-saving and automatic shutdown programs or routines on your computer. If your laptop power plan dims the screen or goes into sleep mode after a few minutes of idle time, disable that. Unplug the laptop's AC adapter cord. Drain the laptop battery. You can just use the laptop until it shuts itself off, or you can wander away and come back when it's gone dark. Make sure that you do not turn it off or allow itself to shut down to conserve power; you want it to run out of power entirely. If you happen to be in a hurry, feel free to exhaust the computer more quickly by playing a 3D graphics-intensive computer game or watching a bit of online video content. Plug the AC adapter back in and wait for the charging indicator light for your laptop to come back on. Once you see that the laptop has begun charging again you are free to do whatever you like, so long as you do not turn the computer off until the battery is fully charged.
Feb 27, 2013 | Computers & Internet
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
How do I check and replace blown fuse - jbl prx 625 - it just shut down - would not start up again
Same thing for me... kid pressed MIC input middle of dance and it shut down. Can't find out where fuse or reset it (not even shown in breakout diagram)
Oct 20, 2012 | JBL Prx625 Prx 625 Dual 15" 2-way Powered...
HP Laptop will not power on even pluuged into a/c outlet
Does it run hot, to the touch I mean? Google a free program called Speccy. Install and run it; look at the internal temperature and see if it slowly rises until the laptop shuts off.
Jul 26, 2010 | HP Pavilion dv6000z Notebook
The TB shut down and will not power back up. Even
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope that works for you as well.
Apr 02, 2010 | Vizio VX37L Television
My Toshiba laptop turns back on when I try to go
The battery seems to be short please remove the battery and use the laptop with the power adapter only to confirm the issue.
Feb 03, 2010 | Computers & Internet
Acer ZG5 shuts down in a few seconds
time to set up a rma and ship it to service center sorry nothing to do but have them repair it now.
Jan 31, 2010 | Acer Aspire One PC Notebook
How to reset a laptop CY25?
Windows XP, right? Click on start, shutdown and then restart!
Is the laptop frozen? Hold down the power button for about 5-10 seconds until power shuts off. Just press the power on again to get it to start back up. Make sure you can NOT reset soft before cycling power on your laptop because you can lose/corrupt data during a cold boot.
Hope this helps,
Bill
Sep 04, 2009 | Fosa CY25 Laptop
I finished downloading a window update from the
This is most likely a hardware issue that coincidentally happened at the same time as you were restarting your computer. Something inside your computer could be having problems or overheating. I would guess power supply first. Try this though, as it just might need to be reset:
1) Unplug the computer power cord from the wall for 1 minute. Plug it back in to the wall. Try to start your computer. If this does not resolve your issue...try step 2.
2) You need to reset your BIOS. Refer to the follow link to accomplish this: Reset BIOS HowTo
Let me know how you make out.
Mar 20, 2009 | IBM ThinkPad T20 2647 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Gateway MD7818u Notebook Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
