Question about Gateway Computers & Internet
Why won't my gateway MD78 power on?
I have tried power reset and that doesn't work.
    Novelist:
    Champion:
  • 233 Answers
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Posted on Nov 30, 2012
2 Suggested Answers
Kelton Smith
  • 56 Answers
SOURCE: my ibm think pad a22m
Chances are that if the fan isn't working then its over heating and shutting down. Check to make sure there is no dust or pet hair clogging it up. If there is then try and clean it out with compressed air. If there is no obstruction then the fan may have died on you. Only thing to do is look into getting a new fan or take it to a repair shop.
Best of luck
Posted on May 25, 2011
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
What's your problem? cd drive won't open
if you have warranty - contact the repair center, if not, open the case and check if the power plug of the Cd/DVD drive is all the way in. unplug it an then plug it back in again.
If that doesn't help - buy a new drive. they are like 30$ nowdays and install it the same way in like the one that doesn't work was installed.
Mar 12, 2012 | Gateway FX685051u Gaming Desktop
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
I have a linksys router and i have tried to access the configuration menu. I have tried the common 192.168.1.1 with no sucess. i have even looked at my details for the ip and it is 192.168.24.1. That does...
Resetting by pressing the button for a total of sixty seconds usually works! While holding the button you can also power cycle the router once or twice. That should put the router back to default settings. Its frustrating sometimes but usually works by prolonged resetting and power cycle. Good luck!
Sep 06, 2011 | Computers & Internet
I have a ZX4931-31e gateway all-in-one. i did a system restore back to factory settings. when it rebooted i was asked to log in and i don't know what the reset administrator password is? i tried...
Have you tried a blank password for the administrator. Just press enter when administrator pops up. If that does not work, try administrator. That should solve your problem.
Thanks for using FixYa!
Aug 02, 2011 | Gateway ZX493131e Notebook
I changed the a/c filter and have been trying to reset the light which says a/c filter change required but it won't reset. Can't understand why because I press reset as soon as it comes up...
All those lights etc on the right side of your dash
are not tied to anything
You don't have to change anything
or do anything. Oil,Cabin Filter etc
THEY ARE JUST GADGETS
Status does cycle
You press Reset & hold
When it says to hold, you
quickly press & hold Reset again
You can just forget all that
Doesn't do anything
You don't sit in your car &
call it up with the status button
& watch it anyway.
Brake Fluid-every 2 years --Flush/All Vehicles
Spark Plugs -- every 3 years,not over 60,000 miles
Fuel Filter --every 3 years
Air Filter --every 3 years
Cabin Filter --every 3 years
Trans & Power Steering--3 years
not over 30,000 miles--EVER on any vehicle
May 28, 2011 | 2004 Lincoln LS
Computers & Internet Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
