Question about RTO Sole F80 Treadmill
Incline displays e2 code - RTO Sole F80 Treadmill
    Top Expert:
  • RTO Master
  • 12,223 Answers
Adjust the speed sensor, test it, clean it, and tight the plug or connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Nov 29, 2012
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
E2, E3, E4 CODES ON A SEARS LIFESTYLER EXPOSURE 1500 MACHINE STARTS OK BUT SHUTS DOWN W/ E CODES AFTER A FEW MINUTES.
an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
Jan 07, 2010 | Exercise & Fitness
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
RTO Sole F80 Treadmill Logo
533 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
