Question about Straight Talk Samsung Galaxy Proclaim Prepaid Cell Phone
No service, even though it shows being in service
It shows that it has full signal, the datta network is connecting and not in roam mode. I tried the over air programming. nothing seems to worj and my plan doesn't exspire till 12/22/2012
  • 59 Answers
This is a fairly common issue with your model phone and I recommend giving straight talk a call. Phones have needed to be replaced in most cases.
Posted on Nov 29, 2012
Samsung mobile SGH-L700. There is a network problem in my set. The phone often goes in searching mode. Please advice how to solve this error.
go into the connection options and set the roaming to off.
,many times when it is on auto the phone will get stuck jumping between local and roaming towers and never really connects to one for very long....when the signal is low or the phone is on the fritz
just make that change though and you will be good to go.
GOOD LUCK AND PLS RATE THIS POST
Apr 07, 2011 | Samsung SGH-L700 Cell Phone
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
My samsung tocco lite has only just started showing a r next to the signal strength what is the R representing
It stands for roaming, which means that the phone is connected to your providers network. You may want to check with your provider to make sure that your not being charged extra for roaming, as this can become costly.
Hope this helps
Ray
Mar 03, 2011 | Cell Phones
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
IPOD Touch wont connect to internet?
Some troubleshooting techniques for this problem would be to connect to another network, maybe your neighbor's (one without a password) and connect back to your network, it could also be a problem with your router/modem even though it shows a full signal, try reconnecting your router or modem.. Whether this works or not, try using the "Easy Wi-Fi" app, its free, download it from the app store, and set it up, it could help in getting a signal or maintaining it. This is a common issue, and sometimes with the ipod touch it may connect and disconnect from the internet. If your computers or other devices are having the same problem you may want to consult your service provider. Hope I helped
Aug 23, 2009 | Apple iPod touch
LG KS360 Signal in and out and roaming all the time
Mine does the same thing. But that actually is because my house has terrible signal in certain parts... The best thing to do is to make sure that where you do makes call ect. is somewhere with very good reception..
Something like that tho can't really be helped.. I think this phone is just generally terrible for getting a good signal.
Jun 16, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
HTC Touch Dimond displays Roaming symbol E beside Signal strength
yea i also have the same problem even though i have my data switched off nd no gps etc. wont i b charged for the e symbol meaning it uses data even thou i have data switched off? this is really weird someone please help us out. thanks
Jun 15, 2009 | HTC Touch P3450 Smartphone
My phone wont let me on the internet
Hey, I have a few possible solutions for you. The big thing is do you have a full signal where you are trying to access the internet? If you are in Roaming you can't use the Internet! Look on your phone and there should be an Icon that indicates If Data Services are Picking up a signal. Try this if you don't have the Data Service Icon ,which normally will be IN ROAMING Mode, then you will know what is wrong. If the signal is perfect and the Data Service is Good, then go into settings and make sure that you don't have AIRPLANE MODE turned on, this blocks incoming calls and the Internet.
May 12, 2009 | Motorola Mobility RAZR V3
Samsung u340 won't show roaming or not
you may wont to contact cricket and get verification on your service area........the roaming triangle should only apply to the device main screen when the towers being used have a roaming contract with the provider. you may very well be roaming but not from your device.....you may be roaming in the cellular network though.....contact cricket from another device for troubleshooting options at (866) 274-2538
GOOD LUCK !!!!!!!!
Apr 11, 2009 | Samsung SCH-u340 Cellular Phone
Keep loosing my wirless connection
Router setup page for a DLINK should be 192.168.0.1 Right click on the D and click on show available wireless networks. There maybe more than showing. If a neighbor has one or if you have another pc it might be trying to use rhe network card from that oc. Make sure that you click on DLINK for wireless connection. You just may see some other connections and find out that it's trying to use another connection.
Mar 18, 2008 | D-Link DSL-G604T Wireless Router
Straight Talk Samsung Galaxy Proclaim Prepaid Cell Phone Logo
242 people viewed this question
Top Straight Talk Cell Phones Experts
justwinwin
Todd Arndt
Todd Arndt
Computer Repairing
Computer Repairing
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
