Question about Worx 16" Electric Lawn Mower
Broken drive shaft - Worx 16" Electric Lawn Mower
How do I replace the upper drive shaft on a Ryobi RBC430SEC brushcutter?
I couldn't find this model on google, but when replacing drive shafts in most brushcutters we used to slide the cutting head / gear assembly off the bottom of the shaft, remove the circlip holding the drive shaft if there was one, slide out the shaft from its square hole in the clutch at the motor end. If the shaft was broken we'd slide the motor part off the shaft to get the broken part of the shaft out.
Nov 10, 2014 | Garden
Oil pump shaft broke off. How can a person remove broken tip up inside motor?
The oil pump shaft is driven by the distributor. If a broken piece of the oil pump shaft is still lodged in the distributor drive socket you may have to remove the distributor to remove the broken piece. Normally there is no retainer keeping the shaft inserted into the distributor drive socket. So when the oil pump is removed the shaft will typically slide, or fall out.
Feb 23, 2011 | 1991 Mercury Grand Marquis
Krone AM322 disc mower pto runs disc will not turn
sounds like a broken shaft in the gearbox!
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Krone Patch panel
Drive shaft
find u a used driveshaft in the salvage yard just make sure you get the correct driveshaft for your turck
Jan 21, 2010 | 1995 Ford F150 Styleside Regular Cab
Broken agitator
If the main shaft were broken, the entire agitator assembly would come out. Usually, there is a plastic adapter that goes from the shaft to the interior of the agitator and is splined to mate with the shaft. A bolt commonly holds the two together, but usually has an uncommon drive head. There may be a removable plastic cap that either unscrews or just pulls off. Hope this helps!
Jan 10, 2010 | Washing Machines
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
The whole car vibrated and had to remove the draft shaft. Whats the effect if i just use the Honda CRV without the shaft as 2 wheel drive. I am told the diff mounting is broken. What is its function. whats...
it is safe to drive the vehicle with front drive shaft only. if there is a mount that is broken, REPLACE IT! there is a danger if that is broken. if the tech already has everything, might as well get it done and enjoy your vehicle. cheers.
Nov 30, 2009 | 1998 Honda CR-V
Engine runs great, no power at head, drive shafts not broken.
The drive shaft is not seated into position properly or the shaft has broken.
Have you had the shaft off recently? If so, take the shaft off again and try to seat the shaft as you gently pull on the rope. If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Troy Bilt Tb70ss Gas Trimmer
Broken 4x4
once you have the passenger side/nearside drive shaft out use some thing long to slide in onto the head of the stuck drive shaft. use something soft like a old wooden broom handle then knock out using hammer. ford have used simple spring clips to keep there drive shafts in and thes are easily come by if deformed or squashed
Jun 02, 2009 | 1983 Ford Ranger
Front axle - front drive shaft Toyota tacoma 1998 4x4
more than like have a broken axle shaft, un hook the rear drive shaft and put it in 4wd if it wont move then you know you got a broken axle shaft or spider gears broke in the pumpkin
Dec 09, 2008 | 2007 Toyota Tacoma
Worx 16" Electric Lawn Mower Logo
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
