Yamaha yst-swoo5 hook surround to lg tv
Trying to hook up system to a new lg tv the yamaha is about7 yrs old thx for a reply
    Sergeant:
  • 344 Answers
Does the reciever have any optical hook ups on it? If not you will have to get a converter fot it,
Posted on Nov 29, 2012
Hawk007
  • 5 Answers
SOURCE: Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Posted on Jul 12, 2008
  • 17 Answers
SOURCE: having trouble connecting my blue
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Posted on Jan 02, 2009
SOURCE: Hookup my surround sound
for verizon cable box to system
Posted on Apr 09, 2009
mlapres
  • 757 Answers
SOURCE: how to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Posted on May 08, 2009
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble...
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
May 26, 2011 | Nintendo Wii Console
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have new computer. My Yamaha speakers Model YST-M7 are older. There is power to the speakers but no sound is coming out. Not sure which hole to plug them into. My choices are: rear l/r surround...
Use the "line-out" connector (usually it's light green in color), and if there is an audio control panel application, make sure the sound circuitry is set for "two-channel" or regular stereo speaker operation. It can be confusing on newer computers which have surround-sound capability built in. Depending on how you set up the sound, the jacks can have different functions. But the line-out jack is what you'll use with basic speakers such as yours.
Dec 28, 2010 | Yamaha YST-M7 Computer Speakers
TV/DVD surround sound through receiver
Try running digital audio from the source - cable/sat - to the receiver. The fewer intervening connections and entities, the better. TV's are NOT considered sound sources for high end purposes or we wouldn't have Yamaha HTR-5860's and better speakers, would we?
Apr 22, 2010 | Yamaha HTR-5850 Receiver
How to hook old surround sound sound up to new lg
if your old surround has either optical or coaxial connections you should be fine. if not you'll have to go with the audio in jacks (video 1,2 etc.) you'll get sound but not true 5.1 sound
Oct 22, 2009 | Audio Players & Recorders
Yamaha YST-MS50 speakers to my i Mac.
You can connect the Yamaha YST MS50 speakers to any audio source that relies on a 3.5mm jack. The YST MS50 should have two audio inputs, so you can use one of them to connect the speakers to your computer. If you don't have a 3.5mm male to male cable, then you can buy that at any electronics store or online.
Oct 11, 2008 | Yamaha YST-MS50 Computer Speakers
Wiring information Re: Yamaha Computer speaker model # YST-MS201
Hi Robert,
Try to locate your manufacturer's websites or surf to google, this might help. You can ask what you need , or maybe they will ask you for a price or fee. You may request free download in google.......good luck..
Mar 23, 2008 | Yamaha YST-MS201 Computer Speakers
108 people viewed this question
 Grubhead
Grubhead
