Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Color problem have a samsung ln-r328w 32 inch. have a prob if the tv wobbles the pic gets blurry and anything black will have red color in it . if i wiggle tv and get it just right the pic clears back to normal
  • yamahar1eric Jan 10, 2009
    cables fit good however if i push on the panel in back where all cables plug in it will clear the picture also
  • 3 Answers
There is a connector that often has a bad solder in this model. It is the cable that goes into the top part of the "M" board inside the TV.
This connector is located sort of in the middle of the top right section of the TV (looking at the TV from the rear). Remove the rear panel by unscrewing the black screws along the edges and 2 screws where the panel attaches to the inside frame in the middle, just above the TV stand port. You may then set up the TV on the stand without the rear panel. When you see the picture deteriorate, apply gentle pressure to that connector, or wiggle the cable, and the picture comes back to normal.
I have been running my TV like this for the last 2 years after having the "M" board replaced twice under warranty, with the same defect coming back almost immediately after the repair.
Posted on May 06, 2009
    Sniper:
  • 59 Answers
Hi it could be a loose cable in the back of the tv
Posted on Jan 10, 2009
My 40" Samsung lcd went to no pic. but the sound works. Help...
Hi there
It sounds like your inverter board went bad. check out on the part number and look for it on ebay you will safe some bucks
Oct 18, 2013 | Samsung LN-R328W 32 in. HD-Ready LCD...
Have lines going accross screen that look like blinking colored d
Bad or loose wire. does this happen only with tv or with dvd and video game too.. check too see if it is every unit then problem is either tv itself or wire connection
Apr 27, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Jul 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Remote control
There could be a cable that is not completely seated inside the set, there may be a software upgrade also that will fix it.
Oct 24, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Weird colors problem
i have a samsung LCD tv 32 inch tv. when switched on the pic is seen for about one sec then goes off. when i change channels the audio changes but the screen is blank. every time i switch off and on the same thing is repeated there is no display on the screen looks like a back screen light fail . can the problem be sorted out by changing the inverter or the whole LCD panel needs to be changed? pl be free to answer.
Aug 17, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
206 people viewed this question
Henry  Thomas
Henry Thomas
