Question about Linksys Wireless-G WRT54G Router
Internet keeps dropping
Whenever I turn on my ps3 I lose my internet connection and have to reboot my router.
  • 826 Answers
Check your router signal strength ,if it is low then it can drop internet connection..
you can try to reboot..its a good option....:))
if everything fail then try to connect using cable and ping with proper IP address and check router signal strength .......
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 29, 2012
  • 258 Answers
SOURCE: keep losing internet connection on the desktop
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Note these down and set these values on your PC by doing the following:-
Start --> Control Panel --> Network Connections --> right click on Local Area Connection --> click Properties
In the small middle box scroll down to Internet Protocol TCP/IP
and click to highlight
Click properties button and enter the values
Click OK
Click Close or OK
2 other things can also stop your wireless connection from dropping:-
Change the Channel transmitted in Wireless Settings
Defrag your hard disk
Posted on Jan 20, 2009
stif_NEC
  • 441 Answers
SOURCE: lost internet connection
Change the wireless channel of the router to channel 1, 9 or 11. Usually other routers use channel 6. If there are other wireless devices on your area like a wireless cellphone, microwave, try to relocate them or the router itself. Place your router on a higher location so that you will be able to get a better signal.
Posted on Feb 09, 2009
SOURCE: vista keeps losing internet connection
open device manager and  look at network adapters and right click on your device and go to properties and uncheck the power management box that allows pc to put device to sleep. this should resovle your problems since windows id defaulted to put device asleep when idle to save power. hope this helps.
Posted on May 20, 2009
CosmaP
  • 409 Answers
SOURCE: Keeps losing connection to internet, have to
You could try updateing the Firmware
Posted on Jul 11, 2009
shadow83
  • 496 Answers
SOURCE: have wireless router in other room PS3 setup can't connect www
  1. Make sure that your wireless Internet is turned on and working properly.
  2. Step 2 Turn on the Playstation 32.gif game console.
  3. Step 3 Access the "Network Settings" screen under the "Settings" screen in the main menu.
  4. Step 4 Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
  5. Step 5 Select "easy" on the new screen that pops up asking what type of installation you want to use.
  6. Step 6 Select "wireless" when it asks you what type of Internet connection you have.
  7. Step 7 Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
  8. Step 8 Select your home Internet when the screen pops up displaying the available Internet options.
  9. Step 9 Save your settings on the next screen.
  10. Step 10 Test the connection to make sure that it works properly.
Posted on Oct 01, 2009
The router keeps losing Internet connection
Keep a eye on Internet light. If it turns RED, then its a problem with internet connection..
As a qucik fix, Try to reboot the router when you face the problem...
Apr 11, 2011 | NetGear DG834 Router
How do you solve the 8013031B error code on the ps3
I have researched your issue and found that people who were experiencing the 8013031B error message resolved the issue in a few different ways.
1. Try rebooting your internet connection. You can do this by turning off the ps3 and disconnecting the the power from both the modem and router. wait 1 minute then plug the power back into the modem. Wait for the modem to establish a connection to your internet service provider (typically takes between 2 and 4 minutes). after the modem gets a connection plug in your router and wait for the router to connect to the modem (typically 1 to 2 minutes). Then power your ps3 on and retest.
If your still getting the same issue try bypassing your router.
If this fixes the problem then there is a issue with the router.
Your best bets are to try updating the firmware on the router and or resetting the router to it's defaults.
If none of the above steps resolve your issue then try resetting your ps3 to it's system defaults. This will cause you to lose all your data so be sure to back it up first on a usb drive.
Please post a follow up to let me know how this goes for you.
If possible please rate the solution I have provided. Thanks.
Aug 25, 2010 | Video Game Consoles & Games
Router is losing connectivity
Could be your Anti virus software. Try to switch it to gaming mode.
Jul 07, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Server conection timed out (80028e06)
Can you access the internet with a computer still?
Try rebooting the PS3 and the router. Reboot the router first, wait a few minutes, then reboot the PS3.
Which firmware version are you running?
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
PS3 keeps losing internet connection
Have your ISP check the refresh on there end (Suddenlink had mine set a 4 minutes instead of 24 hours)
Feb 05, 2009 | Sony Playstation 3 (PS3) Console
2700HGV-B rebooting
Is this device a modem and router in one, or a router only that connects through a separate modem?
If it's a combo device, then a firmware update will probably fix your issue. Your ISP should be able to fix this. Hiding the device on the floor under a drawer could actually cause this because, like any computer, a router needs air flow to cool it off. Routers can overheat and freeze up leading to some weird symptoms.
If you have two devices (router and modem) then make sure it's not the modem acting up.
Mar 17, 2008 | 2wire 2700HG-B Router (2700HGB)
Linksys Wireless-G WRT54G Router Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
