Question about Frigidaire GLTF2940ES Front Load Washer
59 Error code washer Frigidaire Gallery - Frigidaire GLTF2940ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code 59 indicates that that washer is not detecting a tacho signal for three seconds. Contact a professional to move forward accurately. Technician will need to remove the belt from the motor, spin the motor pulley and diagnose the speed control board.
Posted on Nov 30, 2012
the dr
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
  • 125 Answers
SOURCE: dryer door problem
Most likely the door lock is bad, check the wire connections to make sure thay are connected. If so replace the door lock assembly.
Posted on Jan 13, 2008
  • 240 Answers
SOURCE: Error 59 - Washer not spinning
find tech sheet at bottom of washer, behind kick panel on left and check error code there and if listed follow check for motor controller. if not draining either then check drain pump.
Posted on May 04, 2008
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
SOURCE: I have a Frigidaire gallery series front load
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Posted on Apr 10, 2010
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a gas Frigidaire Gallery dryer. There is an error code "LOC". I can't get it to work now.
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Oct 07, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Mar 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Dryer door problem
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
