Question about Infinity HTS-20 System
Infinity HTS-20SUB Subwoofer not playing sound from receiver. Buzz/whine when plugged in & also briefly if pressing up on speaker.
Infinity HTS-20SUB System ver.B - revF board. Sub makes whining buzz for a brief second when plugged in. If i push on the speaker while it is plugged in I hear the buzz. The sub is not pushing any sound out. Sounds like something on the board is bad? The fuse looks fine. I don't see or smell anything that might be bad. Any suggestions?
SOURCE: PS-12 subwoofer problem - Infinity Customer Support number?
Fixed the problem...I just purchased another one online (from a store that has a good return problem) and will return the one that doesn't work! Cheers! :)
Posted on Jun 27, 2008
SOURCE: Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Posted on Mar 23, 2009
  • 133 Answers
SOURCE: When I push my subwoofer cone its work and when i
Looks like a broken copper braid that links the speaker terminal to the cone (from there on it goes to the coil which is underneath the cone).
Check the speaker connection terminals (near the magnet), you will notice that each terminal has a copper braid wire going from that terminal to the speaker cone.
Inspect both braid wires carefully at each end (near the speaker terminal and near the speaker cone), there will either be some damage to the braid at one or more of these four locations or the braid could be actually broken at any of these spots.
The braid can actually be resoldered at the point where it's damaged or broken - this task will require good soldering skills, mainly because this kind of braid wires are difficuld to solder (they are a bit difficult to clean because of their structure and solder won't attach itself well to oxydized copper), but also because some speaker cones are made of plastic which may melt if you overheat it with a soldering iron.
Besides that, when resoldering is being done, only a very short portion of the braid should be wetted with solder because the solder point will become rigid when the solder cools down, and the braid needs to remain very flexible when the speaker operates (if it's too rigid or too short, damage to the speaker cone could occur or the braid could get broken again when the speaker will be playing at a loud volume).
Hope you can have it repaired, it can be done at home, but there are also speaker repair shops where you can get it done (i'm not sure about the prices though).
Anyway, the alternative is to replace the speaker itself.
regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
fkuk
  • 311 Answers
SOURCE: Can I replace the sub woofer in my home stereo
if the impedance of the new speaker matches the impedance of the old one then i dont see why it wont work
Posted on Jan 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: is it possible to hook the infinity bu-1 subwoofer
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Posted on Jul 21, 2010
WHERE IS THE FUSE ON MY hts-20 SUBWOOFER
take the back panel off the control unit(monitor speaker)look on the board for the fuse/or look on the back of the unit sometimes its in a little round jacket on the back of the unit.
Jan 31, 2015 | Infinity HTS-20 System
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
I purchase a denon AVR-591 & now i am using speakers from a kenwood home theater system but know all of the speakers work except the subwoofer does not, know the swbwoofer input has a wire Plus Minus...
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Feb 26, 2011 | Audio Players & Recorders
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
Jul 21, 2010 | Infinity BU-1 Speaker
Sound from 3 channels only
Sometimes what happens is that people r just confused with all wirings.Considering that you have connected the speakers correctly...Now according to u the center speaker is not working
  1. If u have a jack attached at the end of the speakers then try connecting the center speaker jack into the Right front/Right Rear/Left Rear socket at the back of the reciever.Just to make sure that your speakers r fine.
  2. Secondly play an audio cd first,sumtimes a video DVD not being 5.1 channel one confuses a lot.
  3. Assuming that you have checked the center speaker,like I asked u too,Connect it into its proper socket or better connect all the speakers.
  4. Now with the remote you check the predefined equalizer in it n keep changing that [pop,rock,jazz etc] or you might even want it to change it to 5.1 from a 3channel or 2channel Stereo.Everytime you change it listen to every speaker.
  5. Also check that you have increased all the speakers volume one-by-one.
  6. Disconnect any headphones attached.
  7. Switch on the selected source or select another source.
For further details u can check the manual.
The VGA cable of the monitor will work fine.
Jun 03, 2009 | Philips HTS3450 System
PS-212 Suddenly stopped working
I HAVE 4 PS212 AND FROM WHAT YOU ARE DISCRIBING SOUNDS SIMILIAR TO WHAT HAPPENED TO ME. PLAYING THE SUB AT FULL VOLUME AND CLIPPING OCCURED NOT KNOWING THAT THE FAINT SMELL WAS THE VOICE COIL BURNING AND CONTINUING TO PLAY UNTIL KNOW SOUND LESSON LEARNED BUY A BIGGER SUB SYSTEM OR REPLACE YOUR SUB WOOFER.
IN MY OPPINION THIS IS A VERY GOOD PRODUCT WHICH I HAVE BEEN ABUSEING FOR MONTHS . SO QUIT WHINEING AND PAY YOUR DUES.
May 30, 2009 | Infinity PS212 Subwoofer
Infinity HTS-20 System Logo
164 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Matthew Spark
Matthew Spark
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
