Question about RCA DRC8040N DVD Recorder
Dvd lcd says HELLO
I have a RCA DVD Recorder Model number 8060n It about 1 1/2 old. I power it up one day and it will do now is the display says Hello on the front of the dvd recorder. Will not do anything else. Tray will not open. Controls will not respond. Any idea what it could be or where I can get repair for a reasonable price. Thanks Ed
  • 1 more comment
  • belue Jan 22, 2008
    dvd recorder just says hello, no response from any of the controls.
  • f5tornado Sep 05, 2008
    I have the same issue. Started when the power at my home was going on an off several times during a storm. No lightning was present at the time though.
  • Anonymous Dec 13, 2008
    When powered on and disc inserted the menu flickers for 2 seconds on TV and screen goes blank.the DVD recorder displays hello and does nothing else.
GSAN
  • 106 Answers
SOURCE: dvd player/recorder
Like many RCA products that use a DVD Burner, these burners are not high end ones and go out without warning and the first indication is the dreaded HELLO issue. I have tried contacting RCA and the makers of the DVD-RW drives but still I am in the dark as to any possible firmware/software updates for these devices. No fix to this date, only replacing the DVD-RW will resolve this.
Posted on Sep 29, 2008
SOURCE: drc8320n rca dvd recorder
This unit appears to have a faulty power supply module. Poor design. I have the same problem with different caps needed to be changed then those suggested by guest Oct 08.
Posted on Nov 10, 2008
SOURCE: RCA recorder just purchased
I ckd the internet and found that this recorder had a lot of problems and solved the problem by returning it to the store.
Posted on Nov 18, 2008
Mike Adams
  • 19 Answers
SOURCE: RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 27, 2008
Mike Adams
  • 19 Answers
SOURCE: hello?
Symptoms
The unit's remote control and front panel buttons act completely dead. The unit locks up after displaying "hello" on its front panel and refuses to do anything more. In other cases, the front panel display appears completely dead. In this instance, the unit will display "Interface error" or "Interface error! Turn off the power" on the television screen and do nothing more.
In all cases, if a DVD or VHS tape was inserted just prior to the failure, you won't be able to remove either from that point further. They'll remain stuck inside the unit until you've completed the repair contained in the guide below.
Critical information you need to know immediately
If you haven't done so already please unplug the unit's AC power cord and leave it that way until you're ready to begin the repair. Taking this action will guarantee no further extensive electronic or mechanical damage can occur.
Under no circumstances attempt to remove anything stuck inside the unit until the repair has been completed. Should you attempt to do so you'll almost certainly damage its ultra-delicate DVD and VCR mechanisms which are very expensive to replace!
Once the necessary electronic repair has been completed, you'll easily be able to remove them in the customary manner without any problem whatsoever, by simply pressing the EJECT or OPEN/CLOSE button.
Why your unit has recently failed
The cause of all the above symptoms are entirely due to an inherent manufacturing defect in the unit's internal power-supply board, all of which will ultimately fail due to one or more defective capacitors contained on it.
Known brands and models affected
Audiovox DVDVCP01
Durabrand DBDVR01
LG RC797T and RC897T
Memorex MVDR2100, MVDR2102, MVDR2102A, MVCD2102 and MVCD2102A
Panasonic DMR-ES15, DMR-ES30V, DMR-ES35V, DMR-EH55 and more
RCA DRC6200N, DRC6355N, DRC8030N, DRC8040, DRC8052N
RCA DRC8060N, DRC8295N, DRC8300, DRC8300N, DRC8310N
RCA DRC8312N, DRC8320N and DRC8335
...plus many others not yet identified - please contact me if your's isn't listed above
Completely restore the unit yourself in under 20 minutes for just a few dollars
This simple repair doesn't require any prior knowledge or experience with electronics, takes less than 20 minutes from start to finish and typically costs between $1.59 and $5.00 for the replacement parts obtained from your local Radio Shack. All that's involved is simply replacing one (or occasionally just a few more) defective capacitors on the unit's internal power-supply board which are most often running painfully hot to the touch.
The repair guide is provided to anyone who needs it simply upon request
Upon discovering the massive quantity of Chinese manufactured combo recorders having this inherent defect, in addition to the callous manner RCA Thomson and other manufacturers were leaving their loyal consumers out in the cold whose units had completely failed thru no fault of their own, it so enraged me I was compelled to fight back. That was just 3 short months ago and the day this Combo Recorder repair brief was born.
How do I obtain a copy?
Just send an email to my public address provided below. Please include your brand and model followed by "repair brief" in the SUBJECT line. For example, "RCA DRC8335 repair brief" and I'll send it using my private ISP address as soon as possible. Email your request to mikeadams110@yahoo.com
Why don't you just post the repair brief directly on Fixya?
Due to the dynamic nature of its content, the repair brief's constantly being updated on nearly a daily basis, as new information becomes known that wasn't previously. Unless the repair brief is kept at one centralized location, it becomes impractical to manage and keep up to date. Many of the DIY repair forums like Fixya don't even provide the author any way of updating their prior submissions.
Why are your posts often so long?
They're whatever length they appropriately need to be. Nobody likes having to read a long post until it happens to be the one supplying the ideal solution to their problem--in which case it's never long enough!
Can I really do this repair myself?
Over 1,000 combo owners just like you have successfully restored their units using this DIY repair guide during the past 90 days! Below is a tiny handful of the nearly 1,000 follow-up messages I've received to date. Ann's follow-up message is an excellent example demonstrating how new strategic information is provided by your direct feedback and why it's essential the repair brief's kept up to date.
December 27, 2008 received by email from Ann M.
Just like John H, my problem was also capacitor C226, but in my case overheating wasn't the give-away here. Instead, I noticed the bottom of the capacitor appeared melted a little and the top looked like it was slightly bulged. I removed the damaged capacitor and replaced it with a new one rated at 35 volts and now my DRC8335 is working perfectly again!
December 15, 2008 received by email from Mike J.
Mike. Just recently discovered the link to your repair brief posted on AnswerBag and wanted to let you know my previously dead DRC8320N combo recorder is now working perfectly again! Even though I'd never worked with electronics before, following your excellent instructions made the task easy. Bless you for having saved me a pile of money.
December 7, 2008 posted by TinyPeanut on AnswerBag
What Mike says works! My nephew went to Fry's Electronics store in California and got the part he suggested, in our case a 1,000µF 50 volt electrolytic capacitor as that's what they had on hand. He and my brother soldered it in and now my DRC8320N combo's working perfectly again! Thanks so much.
December 04, 2008 received by email from John H.
Mike. Thanks for providing this excellent DIY repair guide. My RCA DRC8335 is now performing perfectly again! In my case, the failure was caused entirely by capacitor C226 which I've just upgraded to 35 volts as advised, purchased from Radio Shack. Thanks again.
December 04, 2008 received by email from Glen
Dear Mike. Simply awesome, my DRC8320N combo's now fixed thanks to you! The only thing remaining I need to do is replace the VCR drive belt so its drawer will lock into place properly. Feel free to share my joy. Thanks again for all your help.
November 25, 2008 posted by Norstar448 on Fixya
I printed out Mike Adam's solution and phoned 2 electronic repair shops who refused to listen to how my machine could easily be repaired. The third said to bring in the info and my machine. He quickly located the part and replaced it and my machine is 100%. Thanks Mike!
November 14, 2008 received by email from Brandon
Mike. Since I last wrote, I've already taken my DRC8320N recorder apart, replaced capacitor #C232 and it's now working great! I repaired it myself without any electronics background or having done anything like this before. It really felt rewarding after putting things back together and plugging it in, to discover everything was working perfectly again.
Posted on Jan 10, 2009
The dvd recorder drc 8052 only said hello, hello , hello . please help me.
You are getting this screen display as you switch on and it indicates that the processor starts up but since it does not move forward there are errors in the main board/processor board which give a wrong feedback thereby shutting off the player.
You need to check the power supply to start with and if all these seems OK , the main board is a suspect.
Feb 05, 2011 | RCA DRC8052N DVD Recorder
My DVD Recorder & VCR (DRC8320N) has Hello on display
Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
Replacement Charger
You can call this number for Insignia parts: 1-888-237-8289. Give them the model number of you unit and tell them the part you need. They should be able to help you. Hope this helps you with your problem.
May 06, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
Nothing Happens but "hello" unless I unplug.
This model seems to have myriad problems and I suspect that it was made in China since the VCR market is fading quickly. If you manage to find warranty info, I'm sure it will require a receipt and probably was only warranted for 90 days as is common with all of our junk consumer stuff these days. The RCA that built that machine isn't the one we remember. I'm sorry for us all-
Dec 30, 2008 | RCA DRC8300N DVD Recorder/VCR
My dvd/vcr combo will not record
follow the below link>>
http://www.geocities.com/toddemslie/vcrdx.html
Hope it helps.
Thanks
Oct 22, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
May 25, 2008 | RCA DRC8060N DVD Recorder
Dvd player/recorder
May 13, 2008 | RCA DRC8052N DVD Recorder
Stuck on "Hello"
This product is known for freezing up. You can get it fixed but it will cost more than you paid for the machine. Best advice, throw it away and buy a name brand recorder. The company will stand behind their products instead of dodging their responsibility of making a decent machine and ripping everyone off. I learned the hard way too, and yes, it hurts the pride.
Sep 11, 2006 | iLO DVDR05 DVD Recorder
RCA DRC8040N DVD Recorder Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
