Question about Jenn-Air 30 in. CVE3401 Electric Cooktop
How to modify the tile to fit the cooktop - Jenn-Air 30 in. CVE3401 Electric Cooktop
    Master:
  • 560 Answers
Can you be a little more specific?
The tile usually sits on a substrate and then the substrate sits on the counter.
Does the new cooktop fit into the current cabinet or does that also need to be modified?
How much more space do you need?
How far past the new cut line will the cooktop cover?
Short answer would be a grinder with a masonry cutting blade.
...and a vacuum.
Posted on Nov 23, 2013
New cooktop is 29.875 "wide for a 30" opening,
Yes it isa safe to seal the cooktop to the counter with caulk.
Jul 27, 2010 | Jenn-Air JED8430 Electric Cooktop
Remove embedded/inset smooth electric cooktop
HI they just sit on the top with brackets holding from the underside or screwed in from under the top sounds like this was put in the tiled after they arestuck downfwith double sided tape as well some times , if nothing works you could go through the top it breaks like a car windscreen hope this helps
Jan 25, 2010 | Cooktops
Stainless Steel Cooktop - Remove Sealant Spray
try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Feb 17, 2009 | Thermador PC366BS Stainless Steel Gas...
Seperate a granite tile backsplash from an existing countertop
the back splash should be held on by silicone or glue very seldom are they screwed on i would bet it is stuck with adhesive silicone so score around the outside of the splash with a utility knife the remove it scoring around the outside will prevent sheet rock damage
Jan 08, 2009 | Jenn-Air JED8430 Electric Cooktop
Wrong type cooktop securing bracket for tiled cabinet
If it were me, I would go to Home Depot or Lowe's and get a small roll of metal strap with holes every 1/2". Should be an easy find and easy installation
Dec 19, 2008 | Electrolux Cooktops
Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Nov 21, 2008 | Cooktops
Ignitors all quit working.
I am solving the same problem on my thermador cooktop now. From what I can tell there is an electrical box inside the unit that generates the spark. called the ignition control unit or ignition device. I bought a new unit at http://wwaparts.com/index.php and had it on my doorstep the next day. The next trip is taking off the burners to get inside your cooktop so you can replace it.
Oct 08, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Installation of new electric cooktop
If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
Apr 22, 2007 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
61 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
