Question about Estate Dryers
Estate heavy duty super capacity 5 cycle 3 temperature dryer won't turn
The dryer will heat just fine it just doesn't turn.
  • 21 Answers
SOURCE: dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Posted on Dec 26, 2008
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
  • 14 Answers
SOURCE: ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
Posted on May 03, 2009
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool estate electric dryer takes three full
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Sep 20, 2011
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
Nov 28, 2011 | Whirlpool LER5636P Electric Dryer
Ultimate care heavy duty dryer is not heating
May 03, 2009 | Dryers
Mar 17, 2009 | Kenmore Dryers
Dryers Logo
148 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
