Question about Sharp LC-C4662U 46 in. TV
With the out of warranty lcd tv Sharp recommended a service in town and they after about 5 minutes determined that I need to replace the inverter boards. They wanted over $500 so I deciced to replace them myself. Installed the boards and after plugging in the power the unit "clicked" then when I pushed the power button it clicked again then aftger about 8 seconds clicked the second time and nothing. The led started flashing steady on-off-on-off. When I first plugged in the led was on solid, now after all the clicking it continues to flash on and off. Does any one have any idea what is going on here? Thanks, Risho
    Top Expert:
  • Sharp Master
  • 45,036 Answers
You still have a power supply problem
Posted on Nov 29, 2012
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 96 Answers
SOURCE: My tv has no power,
John, sounds like if the main isn't the culprit that the Power Supply may have faulted on you. Try ShopJimmy.com, I have used them in the past with great success. I included a link to the PSU from their site. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/new-sharp-rdenca272wjqz-power-supply-unit.htm
Posted on Aug 19, 2011
budmrtn
  • 11361 Answers
SOURCE: I am currently working on a Sharp Lc37sb24u. I was
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Oct 27, 2011
Green light is flashing tv will not turn on held down power on on tv and light turned red then yellow starts for 3 sec and shuts back down any ideas
Your TV has a bad inverter more than likely. There is nothing you can do to fix your TV except replace the part that is damaged. I recommend contacting Sharp and seeing if the TV is still under warranty. Most of the time they can dispatch a technician to replace the part for you. If you have to replace the part yourself then I recommend simply buying a new 32" TV since the cost of repair and parts will easily be in the three hundred dollar range.
Feb 28, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My flat screen Poloroid TV went black, it hissed and cloud of gas or smoke escaped from the back of the TV and now I have no picture just sound. Is it dead?
No troubleshooting needed for this issue. Check the tv's warranty then call the manufacturer to get this tv replaced or fix. If tv's out of warranty you still need to call the manufacturer to ask where is the closest Service center that can fix your tv.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The TV will not turn on, any typical problems?
Not focused at your model pacifically. Typical problems like yours are happening to lots of other flat screen TVs in other brands.
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am thinking about buying a used 65 sharp
I wouldn't recommend buying it unless it came with some type of warranty.
The most common thing you would be looking at for repairs if something goes wrong would be the Backlight Inverter Board or the Power Supply Board. It's what powers the big screen like that. Replacement board for one of them would be well over $200. And we're not talking about labor on top of that from the repair shop.
If you get it, try to get warranty with it. Add on extended warranty if possible.
Jun 04, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Have sound but no picture?
Use the source button to ensure that souce is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
From description it looks like a faulty inverter, I think that is the first part to test.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Apr 10, 2009 | Polaroid FLM-2632 Television
Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Feb 21, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
Sharp LC-C4662U 46 in. TV Logo
46 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
