Question about Exercise & Fitness
What type of lube is used to lube walking belt
Drive motor runs hot
    Top Expert:
  • 12,223 Answers
Use 100% silicone LUBe buy it from www.fitnessrepairparts.com and lube every week of use, Otherwise you will have nightmare of trouble.
God bless you
Posted on Nov 29, 2012
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
ercupa190
  • 12223 Answers
SOURCE: healthrider 500sel
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
Posted on Oct 31, 2011
My starter won't stop running after the car startswhat causes this
I need to know year--make--model?
Sometimes you can take starter motor off, lay in on the ground, hook up jumper cables properly from starter motor to battery, at the least, it should kick out drive gear and spin. When cables are removed the drive gear should retract. Could be something wrong with starter? It could be hung-up on flywheel for some reason? Could be a problem with ignition switch?
Usually two voltage circuits to starter motor, one comes from battery, hot all the time. The other circuit goes hot with key in the start position. The start position should be spring loaded, when you release the key, it should spring back to run position, so that circuit, at starter motor, is no longer hot.
Mar 19, 2017 | Cars & Trucks
My 2004 3400 closed system ,runs hot in town unless heater is on. driving up a mountain pass it gets very hot.on a flat highway runs normal. new t state,resivior cap, both fans work no leaks or smell
Radiator fan motor or radiator fan thermostat defective/
Also there is a relay that operates the fan motor
In town not enough air passing through radiator allowing it to over temp.. With heater fan running acts like cooling fan keeping engine cool
Highway driving ample air passing through radiator without fan.
Hill climbing requires cooling fan/
Hope this helps?
Nov 17, 2016 | Cars & Trucks
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
Belt stops at slow speeds
Check the walking belt is tensioned correctly.
Remove power from the mach.
Most machines you should be able to slide your hand under belt, only to about the center of your palm or maybe your thumb.
if walking belt tension is correct. make sure the delt has lube on it. Your owners manual will determine what type (wax or silicone) or manufacturer to use.
When inspecting the deck (laminated board under the walking belt, which it slides on top of), check for wear or damage.
Worn decks and belts should both be replaced at the same time.
Beyond a walking belt area issue, check the drive belt under the motor hood. connecting the drive motor to the front roller. try twisting the belt on its axis. about a 30degree deflection would be standard. If this belt is loose, the front roller is loosing its drive.
Sounds primarily like a belt/deck lube or wear issue.
Jan 05, 2013 | Nordic Track Nordictrack Track C3000...
Life fitness F1 Treadmill is Jerky when walking or running - what can I do to fix it?
1) Lube the deck belt, this happen because the lack of maintenance, use 100% silicones or wax, check your instr. manual
2) Lube the rollers bearint with wd-40
3) Test the drive belt motor, for cracking or worn belt
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for motor help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 04, 2012 | Exercise & Fitness
I have the Ifit tread mill not sure what model, but when you Are running or walking on it and put your foot down it will pause. What can I do to fix this problem?
This happen because the lack of maintenance LUBE. Now you need to lube the deck belt, probably you have WORN deck belt.
2) LUBE the rollers bearing too.
3) Test the drive belt motor, for worn, crack or adjust if possible.
4) Test the input voltage motor, if there are the Motor need repair.
God bless you
Nov 28, 2012 | Exercise & Fitness
Belt sticking
LUBE inmediatel the deck belt, maybe you have a WORN deck belt. You must lube the treadmills after 5 hours of use, is the maintenance normal.otherwise you will the problem now you have.
2) LUBE the roller bearing too.
3) test the input voltage motor, if there are the motor need repair.
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. See my personal TIPS for troubleshotting motor.
God bless you
Nov 22, 2012 | Nordic Track Nordictrack C2100 Treadmill...
Motor wont run. elevation and console works.
1) the lack of LUBE is the problem, you must do it every 5 hours aprox by use. The system shut down for to protect itself in the electronic component. Maybe you have a WORN deck belt,, time to replace.
2) LUBE the rollers bearing TOO v. important
3) test the drive belt for loose and test the ball bearings motor and replace it if necessary.
God bless you
Nov 18, 2012 | Horizon T92 - Treadmill
I hear a frction noice on the belt and the base while runing
1) LUBE the DECK BELT, you have probably a deck worn, by lack of maintenance propely.
2) LUBE the rollers bearing too, very weel
3) test the belt of drive motor, +test the bearing for lube , need repair too, to due the noise, each motor must be LUBE every 12 months aprox depend of use.
4) if you can not do that, call some tech repair.
God bless you
Jul 16, 2012 | Proform 380 Treadmill Walking Belt
Exercise & Fitness Logo
83 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
