Question about Sewing Machines
I need help with a knitting pattern, do you know who can help me
  • Sewing Machines Master
  • 1,564 Answers
I've used this source a few times. Might help you. Don't forget Youtube great source for lessons and tutorials
Posted on Nov 30, 2012
Where can I get a babies jacket knitted in Butterfly stitch
free patterns in the link. If you can't knit, find you local knitting shop using Yellow pages or Google. They often know people who are happy to knit for you for a small fee.
https://www.google.ca/search?q=babies+jacket+knitted+in+Butterfly+stitch&ie=utf-8&oe=utf-8&gws_rd=cr&ei=LaZaWZWDKMu_jwSIsarYAg
Jul 03, 2017 | Sewing Machines
I am making half throw in the cable pattern also 2 cushions in aran wool how much wool would i need to buy
You deleted the last post as I was just about to post the answer!!
a set of aran knit cushion covers knitting pattern 99p ' to Knit ' Pinterest ...
https://www.pinterest.com/pin/353040058269560085/ Vintage Aran cushion cover set knitting pattern by knitcheap, £0.99 ... CUSHION FROM SQUARES - 250 grams of ARAN in Crafts, Knitting, Patterns ' eBay ... The possibilities for using sweaters for pillows are endless.... and would make great gifts! .... Many owl patterns on Ravelry, but don't have the seed stitch in the "body" ...
Double bed sized knitted throw - Knitting Paradise
www.knittingparadise.com/t-215627-1.html
  1. Cached
  2. Similar
I want to knit my nephew a double bed sized throw how many balls of double knitting wool 100grm balls of wool will I need please. ... im currently crocheting a large granny square bed over and currently am on ball 5 of 1000g aran wool just to ...
Knitting Calculator - LoveKnitting
www.loveknitting.com/knitting-calculators
  1. Cached
  2. Similar
The world's largest range of knitting yarn, patterns, needles, books and ... Circular · Single Point · Double Point · Interchangeable · Sets · For Children · Cable Needles · Crochet Hooks ... Convert between grams and ounces ... Roughly how much yarn will I need for a particular garment? ... Worsted, Aran, 10 ply, 4.5- 5.5 mm.
Estimating How Much Yarn to Buy - dummies
www.dummies.com/crafts/crocheting/estimating-how-much-yarn-to-buy/
  1. Cached
You need to know how much yarn to buy whenever you start a new knitting or crocheting project. You can figure out the yardage by using yarn calculations, ...
HOW MANY GRAMMS OF ARAN WOOL WOULD NEED TO KNIT TWO CUSHION COVERS Google...
Dec 27, 2016 | Sewing Machines
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
Could I use 4 ply instead of 3ply In a dolls knitting pattern
You should probably do a test to make sure that the pattern using 4-ply yields the same size as it would using 3-ply, otherwise your finished item will not be the correct size. Most patterns have a test pattern to make sure your results are what the resulting pattern should be, ie knit a swatch of the pattern and measure it against what it should be according to the pattern instructions. You may need to change the size of needle to get the best result.
Sep 27, 2016 | Sewing Machines
How to increase a knitting pattern Gingersnap
Usually increasing stitches is accomplished by knitting (or purling) twice in the same stitch.
How to Increase and Decrease Knitting Stitches For Dummies
Decreasing is accomplished by knitting (or purling) two stitches together.
Jul 14, 2016 | Sewing Machines
What does the abbreviation SKTPO in knitting stands for?
The abbreviation explanations should be included in your pattern instructions. Pattern designers sometimes use different abbreviations so it is best to refer to the included instructions.
This may help:
Patterns Posh Yarn Luxury hand dyed yarns from the UK
Apr 15, 2016 | Sewing Machines
What does KO mean in the knitting pattern Bernat softee Baby pom pom booties
I do not know what kind of pattern that is. If it is an old pattern then it is probably Knit Off. If it is a newer one most likely it is Knit zero.
Nov 14, 2014 | Sewing Machines
Sewing Machines Logo
48 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
